Thread Tools Rating: Thread Rating: 9 votes, 5.00 average. Display Modes
Old 08-15-2006, 10:39 PM   #241
Originally Posted by craz azn
17x7, ET18. I know its a bit of a stretch but will a 225/45R17 fit?? mainly the fronts.. I know the rears will rub......... opinions, comments?
Not a chance. Even a 215/40/17 would catch the fender occasionally.
Old 08-15-2006, 10:58 PM   #242
Damnit I tryed.... coulda got em for cheap too being R comps and all
Rippin' Proper | E30 | E36 | E36 M3 | E36 Ti |
craz azn is online now   Reply With Quote
Old 08-16-2006, 03:48 AM   #243
Gleb
E30 M20
Gleb's Avatar
Track use fitment question
I am sure that 225/50/15 would fit on a 15x7, 27 offset rim, but I always had 205 tires. Would 225 be safe for track use?
Thanks.
Old 08-16-2006, 08:21 PM   #244
LOL, that makes it a lot worse too. 225 R-comps will run at least as wide at 245 street tires.
Old 08-16-2006, 08:23 PM   #245
Thanks.
Yes, this is an extremely common setup (225/50/15 on 15x7 ET27 Kosei K1's, to be exact).
Some 225's (namely R-compounds) will require a small spacer up front to clear the strut. 3-5mm.
Old 08-16-2006, 08:41 PM   #246
Gleb
E30 M20
Gleb's Avatar
You are right, these are the wheels
I was talking about Toyo T1 R, would I still need spacers?
Old 08-16-2006, 08:50 PM   #247
ZiMMie
Send a message via ICQ to ZiMMie Send a message via MSN to ZiMMie
I thought 225's where too wide for an e30
www.StanceFactory.com
Old 08-16-2006, 08:56 PM   #248
No spacers for 225 T1-R's.
Old 08-16-2006, 08:57 PM   #249
Gleb
E30 M20
Gleb's Avatar
Thank you
Old 08-16-2006, 08:59 PM   #250
Gleb
E30 M20
Gleb's Avatar
Hey mike, you stole my wheels, I will steal your tires
Old 08-19-2006, 02:55 PM   #251
calegrant
If I install borbet 16x9's et15 what kind of spacer will I need to use? I'd REALLY like to go without if at all possible. Also for tire selection, what size would you guys suggest?
calegrant is online now   Reply With Quote
Old 08-21-2006, 06:08 PM   #252
egk2
You'll need at least a 5mm hubcentric spacer up front to clear the struts, no spacers in the rear but I used 10mm's to even out the stance, tires are
215/40/16's but you can go 215/45/16's which fill out the fenders a bit more if you aren't low enough.
2.8litre
egk2 is offline   Reply With Quote
Old 08-22-2006, 11:35 AM   #253
What Ed said, although you may even get away with cheap 3mm spacers up front.
Or, you could throw a small dent in the front strut. I don't really recommend that though.
Old 08-22-2006, 11:09 PM   #254
calegrant
No dents or P.O.S "spacers" will be used. I turned out a set and two spairs while visiting my old high school shop at the end of last year. I'm not a fan of spending 1600 on wheels that are properly balanced to cheap out on mounting them and have em shake like a 40 year old cougars vibrator on a saturday night
Old 08-22-2006, 11:55 PM   #255
Axxe
Over 9 F**KING THOUSAND!!
Axxe's Avatar
^^ Misinformation rocks calegrant
