Thread Tools Rating: Thread Rating: 9 votes, 5.00 average. Display Modes
Old 07-06-2006, 01:23 AM   #226
Lucky bastard. You don't wanna know how much the RZ's cost me in the end.
Get 225/50/15 G-Force Sports or R-S2s. Both sticky as hell.
Old 07-06-2006, 08:30 AM   #227
markw
markw's Avatar
205/50R16
When I get my H&R's + Koni's installed... will the rear rub? It looks iffy to me...
markw is offline   Reply With Quote
Old 07-06-2006, 05:21 PM   #228
Those wheels are 16x7.5" ET20, and 205/50/16 is exactly the same as stock, so yes, it will fit just fine.
Old 07-07-2006, 08:08 AM   #229
markw
markw's Avatar
Hmm. Because the front's look like they're sticking out a bit too far
Old 07-07-2006, 02:07 PM   #230
Maccoretti
Will these fit an e30 with 140mm clearance and butchered gaurds - im not joking its just a drifter with a 13B rotary need visual impact...
http://cgi.ebay.com/ebaymotors/18-Sp...QQcmdZViewItem
Offset:+35mm
I would want to order 18x7.5 for front thou.
Is this going to be feasible? My car runs a lot of negative camber and tucks large rims under rolled gaurds ok.
Maccoretti is offline   Reply With Quote
Old 07-07-2006, 07:17 PM   #231
Get 18x8.5" all around, ET35 should work fine without spacers. Only a 3mm one on the front if the tires have huge curb protectors.
If you really want to stay staggered, the 18x7.5" will also work fine of course.
Old 07-07-2006, 07:18 PM   #232
Remember you gain negative camber as you go lower. The fronts will tuck into the fender; all stock height cars look like that with aggressive wheels.
Old 08-03-2006, 03:12 PM   #233
Gleb
E30 M20
Gleb's Avatar
Will this fit?
There is a company called Revolution wheels and they have 15x7, 19 offset, 4x100 wheels. Will this fit my '87 325i? Thanks.
Old 08-03-2006, 03:14 PM   #234
Gleb
E30 M20
Gleb's Avatar
^^^ They also have 15x7.5 with 0 offset.
Old 08-04-2006, 11:57 AM   #235
Yes, they will fit fine. 215 or narrower tires, unless you have a stiff suspension (coilovers).
The ET0 ones will stick out quite a bit.
Old 08-04-2006, 01:43 PM   #236
Gleb
E30 M20
Gleb's Avatar
Thank you.
Old 08-07-2006, 02:14 AM   #237
King Luis
The King.
King Luis's Avatar
alright...i have a friend who wants to put on these 16 inch rims but needs spacers.
fronts: 7.5 x 16
ET30
rears: 9 x 16
E115 or could it be ET15??
what spacers would he need? is that any other information needed? he's got 205/45/16 rubber on the fronts i think. i'm pretty sure he said he needed spacers for the front but not the rear.
2004 Silver Gray M3
Old 08-08-2006, 05:25 PM   #238
With straight struts, he shouldn't need any spacers (although the fronts will be CLOSE). 3-5mm spacers on the front if the tires have huge curb protectors.
Won't need a thing on the rear.
Old 08-08-2006, 11:10 PM   #239
King Luis
The King.
King Luis's Avatar
thats what i thought...i don't know if it needed it on the front or on the rear but i know it needed some.
thanks.
lets see if i can steal his rims and put them on my car for bimmercruise
2004 Silver Gray M3
Old 08-15-2006, 09:58 AM   #240
17x7, ET18. I know its a bit of a stretch but will a 225/45R17 fit?? mainly the fronts.. I know the rears will rub......... opinions, comments?
Rippin' Proper | E30 | E36 | E36 M3 | E36 Ti |
