Old 04-13-2006, 03:27 PM   #181
Axxe
Over 9 F**KING THOUSAND!!
Axxe's Avatar
The 17x8 will work for sure, the 16x8 will be a bit tighter against the strut. You might have some issues with the fenders, however if you are rolled you should be fine. With a 16x8 you want to shoot for ET20, but ET23 should work fine, worst case scenario a small 3 mm spacer if it rubs on the inside (strut).
Old 04-13-2006, 03:29 PM   #182
M3ntal Kev
M3ntal Kev's Avatar
The only catch is these wheels will be on e30 M3 running gear. ET15-25 works brilliantly well on the e30 M3 and I've found ET20-23 best all around, but then with the 318is fenders, I'm not 100% sure how this will work out.
/// M3NTAL Kev
M3ntal Kev is offline   Reply With Quote
Old 04-13-2006, 03:53 PM   #183
Axxe
Axxe's Avatar
Oh ok, wasn't aware that E30 M3 running gear required a different offset than regular E30's.
I wouldn't worry about the fenders, M3 fenders are boxed out, however they aren't any wider than non-M fenders until you start going up into the fender. Properly rolled and slightly pulled non-M fenders with your stiff suspension setup should be just fine.
Old 04-14-2006, 01:28 PM   #184
Originally Posted by static
Hey need some help
was wondering if it'd be ok if i use 205/55/16 on my e30? (1.5 drop allaround)
i realize that the perfect size for 205 is 205/50, so what disadvantages will i experience?
Alex
They will not fit. The front will permanently be rubbing against the liner.
Old 04-14-2006, 01:30 PM   #185
Originally Posted by M3ntal Kev
Will this size work?
17x8 ET22 (ET40 + 18mm spacer) w/ 215/40/17 on an very low 1991 318is?
Also, what about...
16x8 ET23 w/225/45/16 on an very low 1991 318is?
Trying to work through some new shoe ideas as I plan to swap over the e30 M3 hubs and brakes.
Both of those setups will work flawlessly.
And FWIW, the M3 hubs share identical geometry to non-M. The offsets of one are comparable to the other.
Old 04-14-2006, 01:48 PM   #186
M3ntal Kev
M3ntal Kev's Avatar
That's good to know. So the challenge is going to be the fenders. Well there's only one way to find out.
/// M3NTAL Kev
Old 04-14-2006, 02:23 PM   #187
static
static's Avatar
... or you can just do this
(look for DaveCN's pic of his kodiaks with his fenderjob)
http://www.r3vlimited.com/board/show...t=57624&page=8
Alex
Old 04-15-2006, 12:14 PM   #188
Axxe
Axxe's Avatar
Alex
That's not Dave's car. That's Alex Schipkov's, finished 2nd in national DSP's last year with this beast:
Old 04-19-2006, 02:21 PM   #189
static
static's Avatar
it looks like i might need a similar ^^ fender job. Just mounted 225/50/16 tires on my 16" rims and i rub the plastic in the front at full lock - and that's at stock ride height!!! Also the fronts are like 3-5mm away from the struts - is it gonna get better when i drop it a bit?
When i drop, i am pretty sure the rear will rub the fender. Who's doing a good job at fender rolling locally? I might need that.
I also noticed a big reduction in acceleration with those
Alex
Old 04-19-2006, 06:44 PM   #190
Axxe
Axxe's Avatar
Yeah, Jay said that size would rub. They are an inch taller than stock, so you lose gearing too.
Old 04-20-2006, 12:21 AM   #191
Alex
When you lower it, the tire WILL contact the fender. I've seen 225/50/16's ruin E30 bodywork and paint...it's ugly.
Old 04-20-2006, 01:14 PM   #192
static
static's Avatar
^^ that's why i am thinking to put extra padding on the back (to make up for the drop a bit) - i just need the stiffness not the drop at the back really. Front still looks jacked up
Yea those 50's look quite ugly, but for the price i got them for, you'd pick those up too.
Alex
Old 05-06-2006, 09:49 PM   #193
M3ntal Kev
M3ntal Kev's Avatar
They fit quite well.
17x8 ET40 (w/18mm spacers) for a final offset of 22mm.
215/40/17 Falken RT-615
BTW, I have a small but expensive problem with a bent front strut which is why the passenger side caster is a little off right now. It should be corrected within a couple of weeks.
PS - Jay, please remove the photos if they're not appropriate.
/// M3NTAL Kev
Old 05-07-2006, 06:53 AM   #194
Axxe
Axxe's Avatar
Kev, they are not appropriate, you're making all of us jelous!! BBS whore
Old 05-07-2006, 09:30 AM   #195
Glad to hear it worked out for you, Kev.
