Old 07-12-2014, 10:03 AM   #1486
Originally Posted by Coolguy View Post
Hey everyone,
will the 15" Basketweaves (Euro-only): 15x7" ET24 wheels fit my stock '88 E30 325 iX or will I need spacers?
Thanks!
Yes, with stock 205/55 tires. Looks much better than the iX weaves on the iX.
Old 07-12-2014, 10:05 AM   #1487
Originally Posted by BigD View Post
Jay, what's involved in running a 17x8.5? Again, can't run spacers but am free to do anything with fenders.
ET15?
+18 would be perfect. +15 is great if you find an off the shelf wheel though.
Old 07-12-2014, 03:27 PM   #1488
Coolguy
Thanks for the input!
Now I can order the tyres.
Coolguy is offline   Reply With Quote
Old 07-12-2014, 09:01 PM   #1489
BigD
the misanthropist
BigD's Avatar
Thanks man! This is with a 245 though, should we still go with 18 or cut it down to 15? We have the option of specifying the offset so might as well get it right on.
Old 07-14-2014, 10:42 AM   #1490
BigD
the misanthropist
BigD's Avatar
Basically, do you think we can fit a 8.5" rim with a 245 RS3 (around 9" wide), or should we stick to an 8? And what's the best offset to go with if we can specify any? The main concern is no use of spacers but also the ability to clear the fenders without cutting - we can roll and pull to our heart's content. *might* be able to cut a bit but prefer to avoid it. FWIW it's a high arch sedan.
Old 07-18-2014, 08:46 AM   #1491
Assuming stock style struts with 245/40s: 17x8.5 +18 or 17x8 +25. Fitment is obviously a lot easier with the 8", but that's your choice to make!
Old 07-18-2014, 10:19 AM   #1492
danielbignal
what is our centre bore?
danielbignal is offline   Reply With Quote
Old 07-18-2014, 03:21 PM   #1493
jbrowne
copied and pasted from e30tech forum.
1 Series E81/82/87/88 = PCD 5x120, centre bore 72.5mm and M12x1.5 bolt thread. ET 35-45
3 Series E21 = PCD 4x100, centre bore 57.1mm and M12x1.5 bolt thread. ET 12-20
3 Series E30 = PCD 4x100, centre bore 57.1mm and M12x1.5 bolt thread. ET 15-35
3 Series E30 M3 = PCD 5x120, centre bore 72.5mm and M12x1.5 bolt thread. ET 27-30
3 Series E36 = PCD 5x120, centre bore 72.5mm and M12x1.5 bolt thread. ET 30-47
3 Series E36 M3 = PCD 5x120, centre bore 72.5mm and M12x1.5 bolt thread. ET 35-47
3 Series E46 = PCD 5x120, centre bore 72.5mm and M12x1.5 bolt thread. ET 30-47
3 Series E46 M3 = PCD 5x120 centre bore 72.5mm and M12x1.5 bolt thread. Fronts ET 30-47, Rears ET 20-27,
3 Series E90/91/92/93 = PCD 5x120, Centre bore 72.5mm and M12x1.5 bolt thread. ET 30-45
3 Series E90/92/93 M3 = PCD 5x120, Centre bore 72.5mm and M12x1.5 bolt thread. ET 34-37
5 Series E28 = PCD 5x120, centre bore 72.5mm and M12x1.5 bolt thread. ET 18-25
5 Series E34 = PCD 5x120, centre bore 72.5mm and M12x1.5 bolt thread. ET 13-20
5 Series E34 M5 = PCD 5x120, centre bore 72.5mm and M12x1.5 bolt thread.
5 Series E39 = PCD 5x120, centre bore 74.0mm and M12x1.5 bolt thread. ET 15-25
5 Series E39 M5 = PCD 5x120, centre bore 72.5.0mm and M12x1.5 bolt thread. ET 15-25
5 Series E60/61 = PCD 5x120 centre bore 72.5mm and M12x1.5 bolt thread. ET 15-32
5 Series E60 M5 (Saloon) = PCD 5x120, centre bore 72.5mm and M12x1.5 bolt thread. ET 12-32
5 Series E61 M5 (Touring) = PCD 5x120, centre bore 72.5mm and M12x1.5 bolt thread. ET 12-32
6 Series E24 = PCD 5x120, centre bore 72.5mm and M12x1.5 bolt thread.
6 Series E63/64 = PCD 5x120, centre bore 72.5mm and M12x1.5 bolt thread. ET 14-20
6 Series E63/64 M6 = PCD 5x120, centre bore 72.5mm and M12x1.5 bolt thread. ET 12-20
7 Series E32 = PCD 5x120, centre bore 72.5mm and M12x1.5 bolt thread. ET 19-26
7 Series E38 = PCD 5x120, centre bore 72.5mm and M12x1.5 bolt thread. ET 13-25
7 Series E65/66/67/68 = PCD 5x120, centre bore 72.5mm and M14x1.5 bolt thread. ET 15-25
8 Series E31 = PCD 5x120, centre bore 72.5mm and M12x1.5 bolt thread.
X3 E83 = PCD 5x120, centre bore 72.5mm and M14x1.5 bolt thread. ET 40-45
X5 E53 = PCD 5x120, centre bore 72.5mm and M14x1.5 bolt thread. ET 40-45
X5 E70 = PCD 5x120, centre bore 74.0mm and M14x1.25 bolt thread. ET 37-53
X6 E71 = PCD 5x120, centre bore FRONT 74.0mm, centre bore REAR 72.5mm and M14x1.5 bolt thread.
Z1 E30Z = PCD 4x100, centre bore 57.1mm and M12x1.5 bolt thread.
Z3 E36 = PCD 5x120, centre bore 72.5mm and M12x1.5 bolt thread. ET 30-40
Z3 M Coupe/M Roadster = PCD 5x120, centre bore 72.5mm and M12x1.5 bolt thread.
Z4 E85 = PCD 5x120, centre bore 72.5mm and M12x1.5 bolt thread. ET 45-52
Z8 E52 = PCD 5x120, centre bore 72.5mm and M12x1.5 bolt thread.
jbrowne is offline   Reply With Quote
Old 07-18-2014, 05:04 PM   #1494
Thanks Justin!
Only mistake I've found in a minute of looking up and down is that the E39 M5 is 74.0, like the non-M E39.
Also funny they don't even try to figure out the wacky offset ranges on my Z3M
Old 07-21-2014, 10:13 PM   #1495
BigD
the misanthropist
BigD's Avatar
Thanks again!
Old 07-27-2014, 11:00 PM   #1496
danielbignal
would a 15x10 et 25 work? like whats the max width you could go?
Old 07-30-2014, 01:51 PM   #1497
No, and lots. Depends on literally everything.
Old 07-30-2014, 04:45 PM   #1498
mksol22
I just put H&R sport springs/bilstein suspension on my 89' 325i. im planning on getting some new wheels.
Will ESM-007's 16x8 offset 20 in front, and 16x9 offset 15 rear fit? what would be a good tire size? looking at 225/40/16 kumho's, will i need spacers/ rolled fenders?
mksol22 is offline   Reply With Quote
Old 08-01-2014, 09:53 AM   #1499
205/45 front 225/40 rear would look nice. You will need a minor rear fender roll. No spacers are necessary.
Old 08-01-2014, 05:42 PM   #1500
TSI
Reverse Gear Member
Possible to do 235/40r17 with 5-lug swap? Any rolling or spacing? Assuming E39 style 42s with hub rings.
TSI is offline   Reply With Quote
