Old 05-14-2005, 06:54 AM   #1
Hibbing
Pioneer Elite 56TXi 7.1 THX Receiver FS
Mint condition with box, manuals and receipt. Has extended FIVE year warranty.
Was only used as a preamp. Fantastic high end sound. $1200.
A Powerful Perfomance
The VSX-56TXi rivals what separate esoteric amplifiers would be able to produce as a result of added capacitor size and superior build quality. This receiver utilizes a 15 pound power supply and the largest capacitor in the industry. The VSX-56TXi has an enhanced ability to drive multiple channels, and offers improved bass reproduction, a better sound stage, a lower noise floor, and improved audio clarity. The VSX-56TXi receiver can reproduce an array of high to low-end frequency signals with ease. Pioneer Elite receivers offer equal amplifier power to all channels, eliminating the possibility of one channel dominating a particular sound field. All amplifiers are of discrete MOSFET configuration for low distortion and are capable of handling any current surround format. These receivers offer THX-Select, Dolby Digital EX, DTS-ES, Dolby Pro Logic IIx and DTS NEO-6 surround processing.
Auto Room Tuning
The VSX-56TXi receiver provides a refined multi-channel acoustic calibration system (MCACC) for optimum accuracy in multi-channel sound reproduction. The calibration system works by measuring the acoustic characteristics of the listening area and neutralizing the ambient characteristics that can "color" the original source material. First the MCACC uses the microphone provided to check and test ambient noise levels, the microphone, and speaker levels. Once the initial set-up calibration is complete, the system automatically confirms size of the speakers that are hooked up to the receiver and distance to the listener, then performs a surround analysis. Finally, MCACC checks the channel delay and channel level, before performing the acoustic calibration. During the acoustic calibration process, the speakers will emit a series of pink noise and timing pulses that are received by the microphone and sent to a digital equalizer for final calibration of up to seven channels. Finally, an A/V receiver designed to work in the space you want it to!
Advanced Room Tuning
The VSX-56TXi receiver provides an Advanced MCACC offering all-channel 96/24 analog to digital conversion allowing for manual settings if preferred. The Advanced MCACC feature includes Professional Acoustic Calibration Setup which takes into consideration the reverberant qualities of the listening area and uses this information to adjust the frequency response more accurately for human ears. It distinguishes the difference between the direct sound from each speaker and the reflected sound off of the walls. the Auto Pro feature enables the receiver to output test tones, and automatically adjusts the frequency balance for each speaker in accordance with the reverberation characteristics in the listening room. Manual Pro allows the receiver to measure the room acoustics with reverberation and displays this information on the television connected to the receiver. Once the reverberation characteristic in each frequency band is measured, the user can select which timing frequency to use for manual calibration. MCACC also has the ability to send data to a PC through the RS232C port for a detailed and precise display of the measured reverberation frequency response in the listening room.
Hibbing is offline   Reply With Quote
Old 05-17-2005, 03:36 PM   #2
Hibbing
Bump.
Old 06-03-2005, 02:12 PM   #3
Hibbing
Bump.
Old 06-11-2005, 08:07 PM   #4
Hibbing
Bump.
Old 06-18-2005, 09:46 AM   #5
Hibbing
Bump.
