Old 05-14-2005, 02:41 AM   #1
SimmSimma
Arrow *** tire change ***
I got a flat not too long ago.. Good thing it was close to home.
I went to change it and for the life of me, I couldn't get the rim of the hub.... (yes, bolts were out..lol)
I was trying everything to get it loose... the car shook so much it almost rocked off the jack.
Anyone had this happen to them? What do I do to get it off???
Any help is appreciated. Thanks.
SimmSimma is offline   Reply With Quote
Old 05-14-2005, 02:49 AM   #2
Gamite
Gamite's Avatar
Yeah, I had that problem when I didn't put the hubcaps on my winter wheels
What I did was just sit down on the ground, and kick one side of the wheel till it came of.. It wasn't the smartest thing in the world, but hey, it worked. I probably wouldn't advise doing it, but that's what I did. If you are gonna do this, put a spare tire under the car so it will drop on that instead of the ground.
www.gamite.net
Old 05-14-2005, 03:05 AM   #3
Bliss
Administrator
Had the same issue with my M-lightweight wheels on my e36. I tapped it lightly on the inside rim with a hammer wrapped in cloth( Turn the wheel and tap). It took a veeeery long time though. Good luck...just keep at it, and eventually it'll come off.
For maXbimmer decals, please email info@maxbimmer.com
Old 05-14-2005, 08:48 AM   #4
M50E30
www.bmwclub.ca
M50E30's Avatar
It is just rust.
Take a big hammer and hit the tire untill it comes off...don't be afraid to give it a good wack since it won't do any damage (unless you hit the wheel). Once it is off clean the hub with a wire wheel and apply some grease before you put your wheel back on.
Old 05-14-2005, 10:17 AM   #5
take it to a shop where they can put it on a hoist, its much safer.
If your just swapping rims with tires already mounted, they wont charge much.
Old 05-14-2005, 10:24 AM   #6
DunDan
Ah,....the old wheel-hub problem.
With the bolts off try:
-Kicking the wheel at 4 and 8 o'clock positions
-Lower the lift to put a little pressure on the wheel
-Use a BFH or rubber mallet on the inside of the tire
All my wheels were on so tight I had to use a piece of 2x4 as a spacer directly on the rim and hit it with the hammer. It's easier to do on the front wheels becuase they can rotate. As for the rear, I hammered the inside rim with a 5 foot piece of 2x4 from the opposite side of the car.
Please use caution or goto a professional.
BMW E36 Montreal Blue
DunDan is offline   Reply With Quote
Old 05-14-2005, 11:36 AM   #7
Daydream///M3
or try this.... depending which model bmw you have, if an e46, the jack is perfect such that you can fit the base of the jack against the rotor and the jack part against the inner part of the spoke.......it may take a bit of different positions and when you do get it in there, start jacking slowly.... it will lodge itself out..... make sense?
Daydream///M3 is offline   Reply With Quote
Old 05-14-2005, 12:06 PM   #8
Bmwstylz
Bmwstylz's Avatar
I had the same problem and "luckily" the car actually fell of the jack when I was pounding the wheel and thats what finally loosened it..
alternatively as others have mentioned but a 2x4 behind and pound the shit out of it with a hammer. If you really get desperate put the wheel bolts on loosely and drive the car around the block, try going over small bumps at slow speed if you have to. Risky though!!
"Get rich or die tryin!"
Bmwstylz is offline   Reply With Quote
Old 05-14-2005, 04:28 PM   #9
ara_yaz
Bimmer Fan
ara_yaz's Avatar
Take your car for a spin after you've removed the bolts...a surefire way to get any stubborn rim off
ethirty
ara_yaz is offline   Reply With Quote
Old 05-14-2005, 08:22 PM   #10
M50E30
www.bmwclub.ca
M50E30's Avatar
Bavarian Autosport has these non-metallic discs that you put between the hub and wheel to prevent sticking. Now I wonder if someone sells this local?
Old 05-14-2005, 08:23 PM   #11
SimmSimma
Thanks for the help guys... It finally came off after using some wood and a hammer.
Old 05-14-2005, 09:07 PM   #12
e36_freak
Mostly absent
e36_freak's Avatar
Send a message via ICQ to e36_freak Send a message via MSN to e36_freak
there's a fun way to take off the wheels....... this what our shop teacher told us to do back in high school...........he said to loosen all the bolts. (about half way or so) then take the car out do a hard corner. u'll feel weheel fall out of place. and then slowly drive home........... he's a great teacher but kinda nuts if u ask me...LoL anyone go to streetsville (shitsville) can agree with me
Life isn't about how many breaths you take, but the moments that takes your breath away.
Giving the government money and power is like giving a teenager whiskey and an M5.
[M]i[K]E[¥][M]i[K]E[¥]
e36_freak is offline   Reply With Quote
Old 05-14-2005, 09:20 PM   #13
M50E30
www.bmwclub.ca
M50E30's Avatar
Must do wonders to the threads on the bolts.
Old 05-14-2005, 09:25 PM   #14
Gamite
Gamite's Avatar
lol Seems taht everyone has had this problem, and had their own unique way of getting them off.
www.gamite.net
Old 05-14-2005, 09:45 PM   #15
tatawaki
just use a large (8lbs or 10lbs) sledge hammer, if your worried about denting the rim, use a peice of wood in between, this usually happens when you over tighten the bolts, make sure its around 75ft/lbs when you torque down the bolts. if its a steel rim I wouldn't worry about the wood, just give it a good smack on the inside of the rim with the car in the air.
if you still can't take it off, just take it somewhere and ask them to rotate the tires.
WTB:
2 Left Front + 2 Right Front E46 Fenders
http://www.bmwpower.ca
tatawaki is offline   Reply With Quote
