Old 05-11-2005, 12:07 PM   #1
Ital_325i
Lost in a world of Chaos
Ital_325i's Avatar
Amp/Sub Hookup
Wondering if anyone could hook up an Amp/Sub for me. Already have the wires, just needs to be installed. Aftermarket deck already installed. Looking for someone whos done it before to hook it up. Looking to hook it up ASAP. Car is a 94 325. How much am I looking at? Thanks
Ital_325i is offline   Reply With Quote
Old 05-11-2005, 01:28 PM   #2
Nascar318is
Nascar318is's Avatar
Why not do it yourself? It's not that hard to do. Save some $$$. If you were in Ottawa I'd go and do it for you but miss sauga, is a little far for me...sorry.
The process will take about an hour -2 hours depending on how you run your wires.
Old 05-11-2005, 01:33 PM   #3
ChahalzBMR
Yeah man, it's not hard. Battery is in the trunk so no worry about running thick wires. Just run RCA's and remote wire from the deck through the middle and under the rear seats. Then put them into them trunk. Just connect the wires to the amp and your done. Make sure you get a good ground for the amp! Tons of places for that in the trunk also.
91' CRX Turbo - Sold
94' 318i/M50 swap - Sold
95' 325i - Sold
97' Jetta - Sold
2006 Ford Freestyle - Sold
Looking for a E46 (00-04)
Steve
ChahalzBMR is offline   Reply With Quote
Old 05-11-2005, 03:11 PM   #4
rad318Ti
Send a message via ICQ to rad318Ti
YA man this is def. a "do it yourself" , You'll be surprised how easy it is.. i just installed a sub n amp n my car last weekend, took me about 30 minutes... no lie, and my battery is at the front of the car...... yours is in rear, even easier... just look on which side its easier to get behind the deck... and your laughin... if i didnt live all the way in windsor i'd come do it...
rad318Ti is offline   Reply With Quote
Old 05-11-2005, 03:31 PM   #5
Ital_325i
Ital_325i's Avatar
Well thanks for the positive words, thought it would be more complicated, but, I'll give it a shot.
Old 05-11-2005, 10:02 PM   #6
paul christians
87325is///MR.EVIL
Just take your time on it.............
87is325///2.7L..EVIL.....
Old 05-11-2005, 11:47 PM   #7
notjoe
600rwhp here i come
notjoe's Avatar
Send a message via ICQ to notjoe
LMK when you do it and i'll come over and see if i can give you a hand. I did my own install which turned out fairly decently but still needs to be redone.
What kind of hardware did you get?
notjoe is offline   Reply With Quote
Old 05-12-2005, 12:01 AM   #8
Ital_325i
Ital_325i's Avatar
I got this "AMP wiring kit" Has the block fuse, terminal wire, etc. Just need to find some speaker wire and Im good to go.
Well might get some time to do it Sunday if the weather holds out, if your interested in swinging by, your more than welcome to.
One quick question, to hold the box down, is it alright to just use some velcro to hold it down, or is there a better way to do it? Keep in mind its one 12' in a sealed box, so I dont think it will slid around on the velcro.
Old 05-12-2005, 12:07 AM   #9
rad318Ti
you will be alright... dont use the velcro cuz trust me it doesnt do much at all... it should stay put if you dont drive like a maniac..... but if you see that the box is sliding or tipping over just install sum L brackets and screw them down to teh floor n box... or you can take the subs out n drill straight through the box on the inside and to the floor..
Old 05-12-2005, 12:37 AM   #10
notjoe
600rwhp here i come
notjoe's Avatar
I had issues with the box sliding around and damaging shit in the trunk as well as smacking off the tail lights. Not fun.
I ended up gutting my trunk of everything and laying down plywood for now, eventually i'll carpet the board and make everything pretty again and have the sub bolted down to it.
As for you, i think velcro will make a difference assuming the entire surface which sits against the carpet in your trunk was completely covered, but if you do take that corner a little too fast it will slide. Depending on where the amp is mounted we could wedge a board inbetween the wheelwells so you have a soild place to mount it to so you never have to worry.
How much does the box weigh, roughly?
Old 05-12-2005, 12:40 AM   #11
notjoe
600rwhp here i come
notjoe's Avatar
Oh yeah, PM me with your addy if/when you're ready to do it, maybe the day before
Old 05-12-2005, 08:33 AM   #12
Nascar318is
Bolting it down is a good idea, I have 2 10's and the amp is wedged between the 2 box's and the rear of the car. The only down fall for bolting down your box is......don't get a flat, cause that would suck...
Old 05-12-2005, 11:35 AM   #13
Ital_325i
Ital_325i's Avatar
Box weighs maybe around 20lbs or so. I had it in the trunk just to bring it home, and it slid around. I think I might just use some velcro, cause if I need to get at the spare, I'll be spending double the time removing the box with brackets.
notjoe, will pm on sat
Old 05-12-2005, 02:28 PM   #14
jeffrie
Addict
jeffrie's Avatar
velcro holds close to nothing. I used one of thoes rubber carpet mats from crappy tire.
the smooth side sticks to the box well and the bumpy side sticks to the carpet. And I do drive like an Idiot.
Old 05-12-2005, 03:16 PM   #15
Nascar318is
No you don't
Velcro would work but it won't stick very well to the carpet and you'd need a peice the size of your box. If you face your box towards you and snug against the back seat you could wedge something inbetween the box and the back of the trunk.
And Jeff is right those plastic mats are good, no sliding and easy to take out incase of a flat or changing your rear shocks and coils
