Old 05-09-2005, 10:19 AM   #1
RMKBMW
RMKBMW's Avatar
Location: Ottawa, Toronto, Barrie, Halifax, Victoria, St. Jean.. etc
Question Nitrogen For Tires
I've seen some places are now filling tires with Nitrogen instead of air. I have seen articles about increased gas milage, tire life, and so on. But for the cost of about $5 a tire is it really worth it?
RMKBMW is offline   Reply With Quote
Old 05-09-2005, 10:20 AM   #2
WhadUpp
BIG BIG WHEELS
WhadUpp's Avatar
it is because you wont get any leaks and the tires will last longer.
WhadUpp is offline   Reply With Quote
Old 05-09-2005, 12:38 PM   #3
KIRASIR
Your Nightmare
KIRASIR's Avatar
I don't know about you but I've been doing it for free for years.
Old 05-09-2005, 12:47 PM   #4
Furious
BMW again.
Furious's Avatar
hmmm i got nitrogen at work
Old 05-09-2005, 12:53 PM   #5
BMWags
BMWags's Avatar
Is it because nitrogen is an inert gas? I think it keeps the tires cooler and it doesnt expand and contract as the temperature changes. I know airplanes use nitrogen in their tires because it doesnt heat up like regular air does. Someone who is a chemistry whiz help us out!!
Old 05-09-2005, 01:15 PM   #6
KIRASIR
Your Nightmare
KIRASIR's Avatar
Nitrogen is so called 'dry-air'. Having a very low concentration of water, it expands and contracts less than regular air(78% nitrogen) with respect to increase or decrease in temperature.
It you are talking about F1 applications where +/-1.0PSI change per tire can make a huge difference with traction, then yes, 5 bucks a tire is worth it. For street and everyday use it's useless.
Nitrogen is used in airplanes to minimize the variations in tire pressures at different altitudes.
SL
Old 05-09-2005, 02:06 PM   #7
BMWags
BMWags's Avatar
SL
thanks man, i wasnt really sure
Old 05-09-2005, 04:07 PM   #8
KIRASIR
Your Nightmare
KIRASIR's Avatar
Hmm.. did some reading... looks like the tire pressure is not the main reason for using Nitrogen in the aircraft tires:
PART 25--AIRWORTHINESS STANDARDS: TRANSPORT CATEGORY AIRPLANES
Sec. 25.733 Tires.
(e) For an airplane with a maximum certificated takeoff weight of more than
75,000 pounds, tires mounted on braked wheels must be inflated with dry
nitrogen or other gases shown to be inert so that the gas mixture in the
tire does not contain oxygen in excess of 5 percent by volume, unless it
can be shown that the tire liner material will not produce a volatile gas
when heated or that means are provided to prevent tire temperatures from reaching unsafe levels.
And some other cons of using O2:
a) Ice formation at high altitudes
b) Dry rotting rubber tubes
c) Oxidation of the magnesium rims
SL
SL
Old 05-09-2005, 08:27 PM   #9
RMKBMW
RMKBMW's Avatar
Thanks guys, I think I will get nitrogen in my tires the next time i'm in the shop.
Old 05-10-2005, 12:51 AM   #10
Ant118
BmwAviator
Ant118's Avatar
well knew about the nitrogen but i also know that when u use rain tires when racing filling them with nitrogen is the best
1997 Estoril Blue ///M3 - Track Car
2011 Alpine/Black 335is
Ant118 is offline   Reply With Quote
Old 04-18-2006, 11:31 AM   #11
EMPOWERD
EMPOWERD's Avatar
All Costco locations (with tire centers) use only nitrogen to fill their tires. Just stop by and ask them to refill yours (it'll be free).
My YouTube video
-- RANDY SPARRE --
Old 04-18-2006, 12:46 PM   #12
Quack
Wheelman
Quack's Avatar
and I got tires for you to fill
