Old 05-07-2005, 03:37 PM   #1
ticoupe
ticoupe's Avatar
Help!!!
Just got my new Alpine head unit installed. Everything works fine, radio sounds awesome... but once I tried to put the cd in, the unit reads, but no sound coming out of it what so ever... is there something wrong with my installation, or the head unit is damaged?? Thanks in Advance!
ticoupe is offline   Reply With Quote
Old 05-07-2005, 05:42 PM   #2
Sampson
You need to splice the headunits remote wire into your cars power antenna wire (assuming you're using the stock amp).
Sampson is offline   Reply With Quote
Old 05-08-2005, 12:08 AM   #3
ticoupe
ticoupe's Avatar
do I still do the same if I uses the harness? by doing this I won't damage the head unit right? I think I will give it a try and see if it works... thanks!
Old 05-08-2005, 02:47 AM   #4
Jordan
You know whats cool? When people give details.
like what car this is in. what adapter harness they are using, or if they are smart they directly wired it, if they bypassed the stock amp, if they have amps, what deck they have etc.
Old 05-08-2005, 12:04 PM   #5
jeffrie
Addict
jeffrie's Avatar
^^^ then they wouldn't need help, they wouldn't have a problem.....
If it's a e36 you need to splice the remote turn on (not the antena Alpine turns it off to conserve power) into the BMW amp located on rear wheel well (drivers side). two harnesses on the amp, the upper one, look for the larger wires 2 (+&-). Look for the tiny one right next to them it's the stock amp turn on. Splice it without cutting, or reattach if you do and run the remote from the head unit inline with this one.
Old 05-08-2005, 04:51 PM   #6
ticoupe
ticoupe's Avatar
thanks to all of you guys, everything works perfectly now, awesome!!! Again, thanks for all the info provided!!!
