04-23-2005, 11:24 AM
#31
Car: Z4MC
Originally Posted by DIRTY SIXER
DON' CUT ANY WIRES UNLESS YOU KNOW HOW TO RECONNECT THEM AGAIN..
(properly) sw. means switch
drop the driver dash down. now at the dimmer sw. test the wire that is 12v-it is not gray/red- when you turn the headlite sw. on, play with the dimmer cont. that wire should stay at 12v. cut it, this wire turns on the dimmer cont.. Behind the glove box, the relays for the parking lites are there.
there should be two grey/yellow wires which turn on the relays, cut one, the relay will CLICK OFF (if not reconnect it), the left or right parking lites will go out, then that is the correct wire, do it again for the other relay. you have just found the relay triggers. take out headlite sw., with car off, turn on the first click of the headlite sw. (which turned on the parking lites b4), one wire should give you 12v. that wire is the one you will use to trigger the relays behind glove, and the dimmer sw. (which you cut at first). when you run the wires, do it carefully, and follow the path of the bmw wires, you dont want wires everywhere, remember NEATNESS COUNTS, you should care about your car and the quality of work done to it. now the headlites. fuse box under hood, there you will find the headlite relay. you must get underneath the relay and find the wire that triggers it. it will read 12v when ign. is on. might be geen/yellow. cut it. the relay should CLICK OFF, if it doesnt, reconnect it. now at the headlite sw., test for the wire that gives you 12v when you turn on the headlit sw. all the way, (do this with ign. on), that is the wire which you will run thru the fuse box to the headlite relay. now that i think about it, it mite sound like alot, but thats how it is, some of you, can do it....
i generally charge $90 to do it...
Thanks alot. if it was less i would have pay you to do it, but at 90 bucks, i would rather have a switch made and wire it to fuse 25 to control the light. this is much simpler and easier job.
04-23-2005, 12:43 PM
#32
Car: 328is
Hey, thanks for the help dirty_sixer. I'm just curious, what year of E36s have you done this mod to? Besides your '93. Was it the same procedure? And how much of your dash did you have to rip out? (glovebox for sure)...
I was thinking about doing the same thing (rewiring the relay triggers), but following the diagrams, I couldn't figure out the odd behaviour with the fuse 25 disconnected, so I was worried that the Bentleys were incorrect...
04-23-2005, 01:28 PM
#33
Car: 1993 318 is
not sure exactly which years this goes upto, but as long as all the lites come on with ign., this procedure will work.
dont worry about fuse 25. leave all the fuses intact.
basic review...
the output of the hdlite sw. on the first click will trigger the parking lite relays and the dimmer sw.
the output of the hdlite sw. on the second click will trigger the hdlite relay in the fusebox.
this way its normally functioning hdlite sw.
in this situation though, the headlites (the second click of the sw.) will work only with the ign. on, which i think is acceptable to most of us...
04-23-2005, 01:29 PM
#34
Car: e36 M3, e53 X5
Ok, but the US spec relay should be fine for mine as it's a '96 and the fact that all 1996's started off as US spec cars...Right? Dirty Sixer, thanks alot for the advice.
Originally Posted by mpower1226
as stated above, us spec relay will NOT work with model year 93~95.
only the later model will work. only choice is like above, either you get the switch and wire it, or wire it to oem switch.
04-23-2005, 02:50 PM
#35
Car: 08 F150, 97 540
basic review...
ya if i was to do this your way i would be charging $90 as well...
that is way too complicated for most people and to long and drawn out. it is so much easier to just wire a switch into the console and yank the fuse and replace the fuse with wires.
but it is nice to see the use of the oem switch that is just to much work for me to bother.
what shop do you work at?
04-23-2005, 03:52 PM
#36
wouldu like some tinfoil?
Car: E36-M42, ej22t
DIRTY SIXER
Got pics?
sounds like a PITA but i like how it would be left stock..
Also fuses in a circuit are the weak point adding a larger
fuse to any circuit or removing the fuse makes the wiring
the weak point...
im sure that no ones ran into troubles with the fuse removed though!
on stock lighting..
04-24-2005, 01:50 PM
#37
Car: 328is
I just read this again, and I was pondering over how you used the wire that's hot in the first click position to trigger the parking light relays as well as the interior dimmer...
So is that wire still powered in the second click? I'm just wondering why you don't have to wire the pk lights and the interior lights to the second click as well... (Headlights position)
04-24-2005, 02:25 PM
#38
Car: e36 M3, e53 X5
Well it just dawned on my that I don't need the DRL module and I do need this wiring fix like you guys even though my car is a 96. The reason being is that the 96 M3 was never Canadian-prepped out of the shop and had to be done by the US dealer sending it to Canada which means like someone said earlier, some quick wiring to meet regulations. I have full time lows.....not less intense highs. Man this is pissing me off. I'm sure that it's a common procedure for them, and wouldn't take them more than a half an hour ($50) anybody think the $tealer would just unwire these lights??
P.S.....think link isn't working
http://www.geocities.com/claycar-zi...ianLighting.zip
04-25-2005, 10:23 AM
#40
Car: 1993 318 is
YES, the pk lites will work on the second click as well, just like a normal hdlite sw.
THE shop is safe and sound installations in scar. 4-757-7233.
NO, the stealership do not have a quick wire unfix for the drl on the '96 M3.
it must be done like the way i posted, or the fuse 25 way...
NOW the fuse 25 way will work, but you must do it properly, the correct wire gauge, the right length, the rite connectors, and so on.
if you dont mind having another sw.,then do it that way,
if you wanna use stock oem sw, then the hardwire way...
04-25-2005, 10:26 AM
#41
Car: 1993 318 is
sorry i have no pictures.
but if you get out of my attic, i mite have some
for u. hehe
05-03-2005, 09:18 AM
#42
Car: 1993 318 is
no one is posting anymore about the drls?
looks like i mite have upset some of u.????
or maybe we will all continue later,,,
05-03-2005, 04:22 PM
#43
Car: Z4MC
well, whats the best price you could give us. Im sure if you give us good deals, I know some of the members on board are willing to get it done.
05-03-2005, 06:54 PM
#44
Car: E36-M42, ej22t
for u. hehe
-scurries away to another corner of your attic to hide in
06-04-2005, 07:58 PM
#45
Car: S54
Man, it's $90 for a pretty decent amount of labour, and when that shop is done with the car the wiring will look neater and be safer than any member on this board could do themselves.
