Old 04-13-2005, 12:18 AM   #1
Kithegearhead
Alternator noise
I got a problem and it is driving me nut for the last week and a half. I have noise in my stereo when i play it loud, it sounds a lot like alternator feedback. Now i went ahead and got a rebuilt one, but the noise stayed. ground on the motor is good. I am lost and don;t know where to look. Anybody had this problem before, mayby u can tell me a name of the shop that can figure this out or point me in the right direction. Stereo is stock.
"Want more and more and more and more and more power ahahahahahahahahaha"
Kithegearhead is offline   Reply With Quote
Old 04-13-2005, 01:52 PM   #2
paul christians
87325is///MR.EVIL
it is a bad ground in the alternater
87is325///2.7L..EVIL.....
Old 04-13-2005, 10:51 PM   #3
Striker
Turbo Ready
Striker's Avatar
Don't know if it's still available but you can install a noise supressor. It's bascially a capacitor and diode and is a quick fix filtering DC. An electronic techie can help you with the cap values if you cant find the supressor kit, I can't remember.
SPEED AND POWER IS NOTHING WITHOUT CONTROL,
THANK HITLER, BMW HAS ALL THREE
Striker is offline   Reply With Quote
Old 04-13-2005, 11:35 PM   #4
Kithegearhead
That diode idea is not bad. Thanx.
Old 04-14-2005, 12:06 AM   #5
Striker
Turbo Ready
Striker's Avatar
true, but the capacitor filters all your voltage spikes generated from the alternator which causes the noise.
Old 04-14-2005, 12:10 AM   #6
Kithegearhead
U forcing me to hit the books to get to the truth ;o). Thanks for the advice u seen to know what u talking about.
Old 04-14-2005, 08:51 AM   #7
Striker
Turbo Ready
Striker's Avatar
I hope, I am an old school electronic techie
Old 04-14-2005, 11:12 AM   #8
suicide
on my 3rd 3-series ;-)
suicide's Avatar
Send a message via ICQ to suicide Send a message via MSN to suicide
Umm not sure if i am 100% correct but last time I came accross this problem I asked around and many shops/online forums suggest a "Ground LooP' i think.. basicly loops the signal and filters the noise out.. cheap fix under 25 bux.. but don't hold me to this i never bought the part becuase I sold my e36 and went right to performance e30 so meh.. good luck hope this helped.
suicide is offline   Reply With Quote
Old 04-14-2005, 07:56 PM   #9
paul christians
87325is///MR.EVIL
do not like them (ground loops). Take it back to the shop you got it at.........
Old 04-17-2005, 12:37 PM   #10
Axxe
Over 9 F**KING THOUSAND!!
Axxe's Avatar
They have noise surpressor kits at Canadian Tire. Luckily my Alpine deck came with it standard
Old 04-17-2005, 05:34 PM   #11
Kithegearhead
Original BMW deck is Alpine and i assumed that it had the noise suppressor but it is quite possible that it doesn't so I am going to look into the caps and diodes and see if that help.
Old 04-21-2005, 11:04 PM   #12
Pawel_11_11
ya man, its for sure the prob with your amp. not the alternator...a ground loop will work, what kind of amp are you running....it can't a DE style amp right? (digitial) most digital amps have built in ground loops or noice suppressors. basically you need to either get an external ground loop or change your amp...sometime...RARELY, if you run your RCA beside the power wire that runs from your trunk to the engine, you can pick up some frequencies from that, but once again, if your using good RCAs this shouldn't happen...
Pawel_11_11 is offline   Reply With Quote
Old 04-27-2005, 06:08 PM   #13
spooner_dee
Has no idea whats goin on
spooner_dee's Avatar
Yeah if your rca wires are running side by side with your power wire, thats the feedback noise your picking up. like if you step on the gas you hear it whined up and sounds like a high pitch hum.... if thats what your gettin, simply relocate your RCA wires. I used to have that problem a few years back, moved the RCAs and bam no more feedback
Old 04-28-2005, 10:34 AM   #14
DIRTY SIXER
rule of thumb...
always route the signal wires( rca, speaker, changer, etc) away from main power wires, the bmw stock power wire for the rear battery is on the passenger side.
if anyone would like to do stereo work themselves, just keep that in mind.
this way you would avoid any noise issues that could be from wiring.
DIRTY SIXER is offline   Reply With Quote
