Old 04-11-2005, 10:08 AM   #1
EstorilM3
Stupid question...
Who's Mark DeSilva (sp?)?
Anyone know?
I heard he's selling software upgrades.
This would be in Toronto area, I assume.
EstorilM3 is offline   Reply With Quote
Old 04-11-2005, 10:26 AM   #2
SkycityBMW
SkycityBMW's Avatar
Here . . should help try PM . . . MarkD
www.dsylva-tech.ca
SkycityBMW is offline   Reply With Quote
Old 04-11-2005, 11:53 AM   #3
JazzM
Great guy, did amazing work on my S54 DME programming. I highly recommend him.
T.
T.
Old 04-11-2005, 12:16 PM   #4
BRAD 82
BRAD 82's Avatar
Send a message via MSN to BRAD 82
how much does this affect your gas mileage and is it worth doing this on a 318is?
BRAD 82 is offline   Reply With Quote
Old 04-11-2005, 12:39 PM   #5
JazzM
if anything you get better gas milage (power increased by changing timing - engine runs more efficiently).
T.
T.
Old 04-11-2005, 12:48 PM   #6
EstorilM3
T.
BUT, it appears that one has to use 94 octane gas which may not be readily available in your area.
I know it is NOT in mine!
Not sure how well the software adjusts to lower octane Super.
I was all for it, 'till I saw the 94 octane gas requirement for the E36 M3's.
Now, I'm not sure...don't want to cause engine damage or keep fouling the plugs or whatever...
If the software adjusts itself to the lower octane automatically, then what's the point of using it - where is the advantage???????
Except for the deletion of the speed governer, which can already get me into a whole lot of problems with the cops.
Old 04-11-2005, 01:30 PM   #7
JazzM
removal of the governor is done by pretty much any tunner.
most likely they will also raise your RPM limit
the higher octane gasoline requiremements goes back to my timing argument since the timing can be advanced more without risk of detonation if-f the gas has a higher octane count which in turn will produce more power.
You can get tunned software for 91,92,93,94.....110,etc.
T.
T.
