04-11-2005, 01:43 AM
#1
Car: '88 E30 M50
new to the maXworld, and already starting with the questions
hi everyone,
i am fairly new to maX and ive been using this forum to get aquainted with the BMW world. i'm currently in the market for a 1992-1997 e36  4door. Also, while searching the forum i came upon common problems for this model but i would like more information on body rust/bubbling. Where are the common areas of corrosion and how big of an issue is rust with these cars?
(i'm sure the amount rust varies depending on the care the previous owner gave it, but usually it follows patterns nonetheless)
thanks in advance, cheers!!
04-12-2005, 02:44 PM
#2
Car: '88 E30 M50
does anyone have any rust horror stories regarding this model?
04-12-2005, 02:47 PM
#3
Car: SUV
I find the nose panel to become rust very quickly but that is thanks for the chips on highway...most of the body is built pretty solid. I have a few rust spots on the rear doors. That's all.
91' CRX Turbo - Sold
94' 318i/M50 swap - Sold
95' 325i - Sold
97' Jetta - Sold
2006 Ford Freestyle
Looking for a E46 (00-04)
Steve
04-12-2005, 03:19 PM
#4
Car: Granitsilber E36 325i
I have a 92 325i . . . not much rust on mine . . just by the door.
and as Chahalzbmr said the nose panel . . damn rocks ! !
Oh yeah . . . . Welcome to maXbimmer ! ! !
04-12-2005, 03:26 PM
#5
Car: 1997 M3/4
ive seen a couple of older ones have some rust around the trunk area, but i doubt they were taken care of...most are pretty clean.
04-12-2005, 04:49 PM
#6
Car: is not a real ///M5
On the 92, I would also be very wary of the rear-subframe cracking issue. Just some food for thought...
www.enthusiastauto.caContact if you are looking for a car
His--2000 BMW ///M5 .:Jet Black on Black:. Individual - Style 65 Wheels; 9.5" Square Set up;275 Tires;10mm/3mm Spacers; Black Kidneys;Muffler Delete; 3.5" Dual Tips; Beast Power Sway Brackets; "Dinan" Ducts; E60 SSK; BC Coils
Hers--2000 BMW ///M5 .:Avus Blue on Grey/Black:. '01 Exterior Upgrades; E60 SSK
04-12-2005, 05:14 PM
#7
Yeah, bmwm5lover . . . . I forgot about that issue . . . depends on how the previous owner(s) drove the car.
BMW discovered that over time, due to the bending of the rear of the chassis in conjunction with the movement allowed by the rubber bushings in the rear, the chassis mounting points for the subframe would flex, weaken, and if left unattended, rip out of the chassis. The stock mounts are basically a flat plate with an internally threaded tube that are welded to the chassis. The flex of the rear subframe causes the threaded tube and mounting bolt to act as a lever arm at the point where the flat plate is welded to the chassis, weakening the surrounding sheet metal. Due to the direction of force of the torque applied by the drivetrain on the subframe, the first mount to rip out is the passenger’s side front mount, followed by the drivers side rear mount.
http://www.turnermotorsport.com/html..._ID=4111225649
04-12-2005, 06:39 PM
#8
The King.
Car: Silver 2004 BMW M3
is it only the 92 or 92 to what?
2004 Silver Gray M3
04-12-2005, 08:01 PM
#9
I *believe* it was 92's, and a few early 93's..Someone correct me if I am wrong.
04-12-2005, 09:57 PM
#10
Car: '88 E30 M50
wow, sub-frame cracking sounds pretty serious, what kind of preventitive maintenance is done to remedy this? are there reinforcing plates available to weld to the frame?
04-12-2005, 10:47 PM
#11
Comfortably Numb
Car: USDM Skyline 350GT
Almost all E36 had rear subframe problems as well as the rear shock mounts being torn from the body. Also, the water pump issue was a problem. Other than that E36's were built pretty solid
Welcome to Max
Bobby
'05 Skyline 350GT 6MT - Ivory Pearl/Stone
04-13-2005, 09:18 AM
#12
I guess you didn't click on my link above . . .
04-13-2005, 09:41 AM
#13
Car: '88 E30 M50
ooops!!! sorry man....rookie mistake
