Old 03-06-2005, 03:48 PM   #1
A-4WD
Formerly ara325
A-4WD's Avatar
Engine running cool
Hey, I just noticed yesterday and today that my engine is not reaching normal operating temp. It passes the 1/4 mark, but ends up between 1/4 and 1/2, however it is more skewed to 1/4 rather than halfway. I have < 5 k kms on a new thermostat. Could there be another PITA causing this issue?
Any help would be appreciated
thx,
Ara
2014 X5 XDrive 35i - Current
2010 X5 XDrive 4.8iS - Traded
1990 325iS - Sold
1985 318i - RIP
A-4WD is offline   Reply With Quote
Old 03-06-2005, 04:22 PM   #2
Mitch555
Retired MaXmember!
Mitch555's Avatar
thx,
Ara
What kinda thermostat did you buy? Sometimes some thermo's don't work too great with some cars. Also check to see if anything is loose.
MY ENGINE SWAP: HERE!
Life Is A Tough Teacher, It Gives You The Test Then The Lesson.
Originally Posted by Mystikal
just do it once, do it right.
Mitch555 is offline   Reply With Quote
Old 03-06-2005, 04:30 PM   #3
A-4WD
Formerly ara325
A-4WD's Avatar
i dunno, OEM thermostat...it was fine when it was like -39, but now that it's only like -5, it's not hitting normal temp.
check to see if what's loose? rad hoses, connections etc...
1990 325iS - Sold
1985 318i - RIP
Old 03-06-2005, 05:06 PM   #4
paul christians
87325is///MR.EVIL
there is 2 of them 145 to 180 i thick..........
87is325///2.7L..EVIL.....
Old 03-06-2005, 07:12 PM   #5
A-4WD
Formerly ara325
A-4WD's Avatar
i'm gonna check my Bentley...i dunno why i didn't do that in the first place.
1990 325iS - Sold
1985 318i - RIP
Old 03-06-2005, 08:18 PM   #6
Gamite
Gamite's Avatar
u check your fan clutch?
www.gamite.net
Old 03-06-2005, 11:10 PM   #7
A-4WD
Formerly ara325
A-4WD's Avatar
not yet...the snow hasn't let up since noon.
1990 325iS - Sold
1985 318i - RIP
Old 03-06-2005, 11:30 PM   #8
Pawel_11_11
its most likely your thermostat! I had similar prob, and some of them dont like to adapt to work, make sure your gaskets are well alligned and that the bolts are properly torqued. Also check and see if you have constant flow of antifreeze when your car is still cold. When you start your car in the morning your thermostat should be closed to allow your engine to warm up, if you open the antifreeze cap and look inside you should be able to see if the fluid is flowing throughout the system. I had similar probs with my e36, and I went through 2 thermostats before I got it heating properly
Pawel_11_11 is offline   Reply With Quote
Old 03-07-2005, 05:44 PM   #9
BMWF1
Guest
Posts: n/a
mine runs hot you wanna swap
Old 03-07-2005, 06:31 PM   #10
blacknblue-e30
Just black, No blue
blacknblue-e30's Avatar
Send a message via MSN to blacknblue-e30
I just had this problem, car would be at 1/4 when it was -26 a month ago, and still the same 0 degrees the other day, I had the wrong thermostat set to the incorrect temp., i got the right one now, and its where it should be. Just dont leave it till the summer, driviing around in low temps with the car not heating up to normal temps obvoiusly isnt good for it.
blacknblue-e30 is offline   Reply With Quote
Old 03-08-2005, 12:17 AM   #11
SebSter
SebSter's Avatar
i have the same problem, just changed the thermostat maybe a month or two ago with one i bought from the dealer, and still doesnt heat up any more. I dont see why the dealer one would be set to the wrong temp, any other problems to look for?
SebSter is offline   Reply With Quote
Old 03-08-2005, 12:39 AM   #12
Gamite
Gamite's Avatar
seb, check fan clutch.
www.gamite.net
Old 03-08-2005, 01:12 AM   #13
SebSter
SebSter's Avatar
Thanks, will check it out when the weather warms a little.
Old 03-08-2005, 01:16 AM   #14
Gamite
Gamite's Avatar
u could probably go check right now, just run the car till its warm, and try to spin the fan, if it doesn't spin freely, then its the clutch.
www.gamite.net
Old 03-08-2005, 01:21 AM   #15
SebSter
SebSter's Avatar
allright maybe ill give it a look tomorrow if i have some time, thanks again.
