Old 03-05-2005, 11:33 PM   #1
Guelphguy
Guelphguy's Avatar
How to read Rim specs??
Got some Rims for my 90-535i, well at least thought I did....got through an auction house in London...anyway, have e-mail dialogue confirming that these rims are for a 5 series....but for fun today, thought I would e-mail the manufacturer "RONAL" and they tell me that they are only for a 3-series....
Here is what came off the Rims:
8J X 17H2 ET35
So is that right? These are wrong??
Here is what the Mfg said:
" Hello. Wheels are made for 3 series BMW, not 5.
Do they have a 20mm spacer in the back of the wheel, ? if so, they’ll fit, otherwise 3 series only, unless you want to send them here, and we can modify to accept spacer, but app. $75/wheel inc. spacer to do, and freight"
I am kinda P.O.'d realizing that these may not fit!!! Here is a pic of the Rims: THey are a RONAL R-7 - 17 X 8" look great!!
1990 535ia (gone), 1994 525i 5-spd (gone), 1980 Corvette, L82 (gone) - 2007 Chrysler 300C (gone) - 2003 530i M-Sport
Guelphguy is offline   Reply With Quote
Old 03-05-2005, 11:38 PM   #2
Jordan
The wheels are 17in in diameter, 8in wide, with an offset of 35.
I don't know that much about proper offset ranges for e34's, but Ronal is most likely right. Spacers can fix your problem though.
Old 03-05-2005, 11:45 PM   #3
Guelphguy
Guelphguy's Avatar
Yeah, I am sure Spacers would work, however not really intersted in sending them to the US at $75 per piece plus some $100 plus in shipping??? I think I would just resell them in that case!
Old 03-05-2005, 11:57 PM   #4
M50E30
www.bmwclub.ca
M50E30's Avatar
You can get away with a 15mm to 20mm spacer ( www.amimotorsports.com ). Now another thing to check is the center bore of the wheel.........sounds like it may be on the small side.
M50E30 is offline   Reply With Quote
Old 03-06-2005, 12:05 AM   #5
Guelphguy
Guelphguy's Avatar
Man o' man....starting to sound like a lot of mucking around!!! Dammit!!
Think I might just flip these and put them up for sale....start over looking for some rims at the proper size.....
Old 03-06-2005, 12:05 AM   #6
Guelphguy
Guelphguy's Avatar
Being 17" 3 series, spring around the corner, I imagine I should not have that much trouble selling these eh?
Old 03-06-2005, 12:18 AM   #7
M50E30
www.bmwclub.ca
M50E30's Avatar
You will probably be able to sell these quickly but expect a LOT of low ballers on maXbimmer. The proper and safest bolt on spacers (15mm to 20mm) from AMI go for $166/pair.
(not exact ones they sell)
Old 03-06-2005, 09:50 AM   #8
Guelphguy
Guelphguy's Avatar
What are these worth if I need to sell on here?
Old 03-06-2005, 12:01 PM   #9
Guelphguy
Guelphguy's Avatar
looking at another set now off fleabay (I'll never learn).....anyway these are off a 98 750IL with at ET15 offset...says they are fine for 5 series is the e34 offset not ET20??? Does that matter?
Edit/Delete Message
Old 03-06-2005, 12:05 PM   #10
M50E30
www.bmwclub.ca
M50E30's Avatar
Edit/Delete Message
What is the width of the wheels? Sounds like they the staggered M-Parallel wheels to me.
Old 03-06-2005, 12:13 PM   #11
Guelphguy
Guelphguy's Avatar
8.5"
Will these work?
1000 Miglia 16" x 8.5"
Old 03-06-2005, 06:56 PM   #12
M50E30
www.bmwclub.ca
M50E30's Avatar
8.5"
Will these work?
They will fit. I think the biggest you can go is 8.5" in the front and 9.5" for the rears as long as the offset is correct.
But why go 16"?
