Old 02-26-2005, 05:30 PM   #1
RevShoT
RevShoT's Avatar
For Sale: 3:91 e36 differential $150
for sale:
3:91 open differential for sale
selling cause i upgraded to LSD
$150 OBO
Old 02-26-2005, 05:39 PM   #2
Kal
maxRealtor
Send a message via MSN to Kal
RevShot... will this fit an auto 94 318i? I'm in desperate need of one.. let me know as i will grab this if it will give me the same or even better performance then the current one I have now (which is messed up anyhow)
Kal is offline   Reply With Quote
Old 02-26-2005, 10:41 PM   #3
RevShoT
RevShoT's Avatar
i belive u will need new axles (from a 6 cylinder model) to make this work with a 318, dont quote me im not positive!
this rear end having the gearing will make your car quicker and pull harder off the line, but you will redline a lot sooner then with your stock rear end
Old 02-27-2005, 12:41 PM   #4
Kal
maxRealtor
RevShot if you can find out for me 100% I will grab this off of you! I dont know where to find this info out so if you know where I can look this up that'll be great.
thanks,
Kal
Old 02-27-2005, 12:51 PM   #5
RevShoT
RevShoT's Avatar
just noticed yours is auto.... i think an auto 318 came with a 4:56 rear end or something, so this rear end will actually make you a bit slower off the line, but you will increase top end speed and better milage on the highway
ill check about the axles, btw i can install it for you too
Old 03-01-2005, 06:02 PM   #6
RevShoT
RevShoT's Avatar
bump
new price $350 installed into any 6 cylinder e36
Old 03-01-2005, 10:41 PM   #7
Kal
maxRealtor
shit .. so it'll make me slower off the line? ****kkk that i'm already slow as it is off the line lol ... thanks anyhow though .. i'm going to find out for sure if it will slow me down just to confirm.
and thanks for the offer of installing it but I have a mechanic shop so i'll be fine with the install
Kal
Old 03-02-2005, 01:05 AM   #8
RevShoT
RevShoT's Avatar
offer is to anyone who wants it
$150 or $350 installed
currently it is set up to be a direct swap into an M car
(6 bolt drive shaft flange and M output flanges for the axles) can be removed and non M ones can be used
Kal, measure the space on your sub frame where the differential slides into, im pretty sure this diff to too big to fit your subframe, measure the box in the sub frame and the distance between the "ears" of the differential (the 2 mounting spots of the diff)
