Old 02-12-2005, 12:21 AM   #1
WhadUpp
BIG BIG WHEELS
WhadUpp's Avatar
Harddrive problem
For some reason my computer cant read my secondary hard drive although in the bios it recognizes it. When I go into 'my computer' it doesnt show up. I tried repluging the power and sata plugs but it still doesnt read it. Could my hard drive be faked. Good thing my primary drive works and all else is good with Windows but all my games are in my E drive but it doesnt show up.
Anyone have this happen to them and know what it could be. It happened once before and all i did was unplug the drive and replug it and it showed up again but this time that doesnt work.
Any help is appreciated, thanks
WhadUpp is offline   Reply With Quote
Old 02-12-2005, 12:29 AM   #2
MP328
Krv Svoju Za Bosnu Moju
MP328's Avatar
Send a message via MSN to MP328
what about system managment does it show up there? go to my computer (right click) -> manage -> disk managment! does it show up in there???
try downloading some manufacturer disk tools and running them
MP328 is offline   Reply With Quote
Old 02-12-2005, 12:39 AM   #3
WhadUpp
BIG BIG WHEELS
WhadUpp's Avatar
Just tried what you recommended checked there but it doesnt show up.
Thanks for trying to help MP328
all it says is Disk 0 Basic drive C D healthy
Disk 1 Dynamic Offline
Old 02-12-2005, 12:45 AM   #4
5style
Hatters gon Hatt
5style's Avatar
go into dos, from a boot floppy, and fdisk the drive, you will lose all info, but it might mount afterwards, if it turns and doesn't make wierd noises, its still prolly ok, BUT a virus could make it unmountable until you format it ( FDISK IT). if it shows in bios, it runs, otherwise your bios would hang if it didn't work properly.
Old 02-12-2005, 12:46 AM   #5
SickFinga
SickFinga's Avatar
Is it a new HDD or it worked before and just disappeared?
Old 02-12-2005, 12:47 AM   #6
WhadUpp
BIG BIG WHEELS
WhadUpp's Avatar
It worked before and just disappeared
I dont have a floppy drive and Im reluctant to lose all my good games. I just got this new gaming machine
The harddrive shows up in bios WD1600 which is my drive E which is not partitioned
Old 02-12-2005, 12:49 AM   #7
5style
Hatters gon Hatt
5style's Avatar
ok, get a disk utility program off the net to check it over then! Also, check you bios, and make sure the drive is actually enabled in bios, your bios might have disabled it. Also, please tell me if you are using a raid setup or not?
Old 02-12-2005, 12:52 AM   #8
WhadUpp
BIG BIG WHEELS
WhadUpp's Avatar
no raid, my 80 gig hard drive is partitioned c,d and my 160 harddrive is E
I'll recheck my bios but I think it is enabled. Ill check for a utility prog. but I hope I dont have to lose over 34 gigs of games.
Old 02-12-2005, 12:55 AM   #9
5style
Hatters gon Hatt
5style's Avatar
ok, if it is enabled, in general bios features, and the computer doesn t hang on system check before OS boot, then the drive is operational. CHeck the jumpers on it, make sure its not on cable select, in guessing this is a slave, not a master drive, so set it accordingly, as this could be your problem too. if none of this works, then you are pretty much SOL and should rebuild the drive with FDISK, basically putting a fresh partition on it, ( the whole drive) a way to FULLY reformat it with no archives.
Old 02-12-2005, 12:56 AM   #10
5style
Hatters gon Hatt
5style's Avatar
also, if nothing works, unplug the drive, boot, turn off, plug in and boot again.
Old 02-12-2005, 12:57 AM   #11
WhadUpp
BIG BIG WHEELS
WhadUpp's Avatar
Thanks 405Style, will do
Old 02-12-2005, 01:08 AM   #12
AMG_POWER
500HP Member
same problem what i have!
AMG_POWER is offline   Reply With Quote
Old 02-12-2005, 01:10 AM   #13
WhadUpp
BIG BIG WHEELS
WhadUpp's Avatar
AMG POWER, did you get it working after?
Old 02-12-2005, 02:44 AM   #14
AMG_POWER
500HP Member
well, I could see that all my files are there, but not yet, didnt have time to work on that... It was some free trial version.
Old 02-12-2005, 12:36 PM   #15
WhadUpp
BIG BIG WHEELS
WhadUpp's Avatar
Im going to reformat everything and start fresh again , who know if it was a virus that caused it. After this it should work hopefully
