Old 02-05-2005, 07:15 PM   #1
mmpower
Question After Aftermarket Radio Installation????
Did you have any issues with radio reception after installing your aftermarket head unit???
I just installed my Pioneer head unit and FM Radio reception is crap!!!
It's either I forgot to plug in the attenna (which I know I didn't forget) or I just have a shitty head unit!
Anyone?? If you did, did you do anything to fix the issue??
I have a E46 by the way!
mmpower is offline   Reply With Quote
Old 02-05-2005, 09:51 PM   #2
Gianpaolo_E46
prob not connected properly to antenna. check the connection, it might have gotten lose when u pushed the deck in
Gianpaolo_E46 is offline   Reply With Quote
Old 02-06-2005, 12:27 AM   #3
Jordan
I'm not sure about e46's but on e36's there is no "antenna"
There is a secondary matrix on the rear windshield. Looks just like a defroster matrix, but its sperate and serves as an antenna.
The signal from this antenna is sent through a preamp and signal booster prior to being sent to the stock deck which must also boost the signal.
Aftermarket decks in e36's I have worked on are NEVER nearly as good as the stock deck for FM reception.
But what do I know... I hate radio... I removed my antenna and welded up the hole
Old 02-11-2005, 09:42 PM   #4
Griff
You could also try an aftermarket in-line antenna amp. For the $30 or so, it's worth a shot.
Phil Griffin
Toronto, Ontario
'86 325es
'85 VW GTI VR6
Griff is offline   Reply With Quote
Old 02-11-2005, 10:11 PM   #5
jeffrie
Addict
jeffrie's Avatar
It's a weird connection that is by itself on the annt side of the original deck on a e36. I cut it peeled the insulation off then wired my annt power wire from the head unit (could use amp turn on if you havn't got one for the annt) to the solid copper part.
Could be the same for an e46.
Old 02-11-2005, 10:46 PM   #6
ZiMMie
Send a message via ICQ to ZiMMie Send a message via MSN to ZiMMie
Radio its good for traffic. I love 680 news in the morning.
www.StanceFactory.com
Old 02-28-2005, 08:56 PM   #7
kornstar369
kornstar369's Avatar
who needs antenna now a days any ways,lol, i say dunn worry about it
kornstar369 is offline   Reply With Quote
Old 03-04-2005, 11:41 PM   #8
DIRTY SIXER
youiopi
DIRTY SIXER is offline   Reply With Quote
Old 03-05-2005, 08:45 AM   #9
kornstar369
^^ wats that?
Old 03-05-2005, 11:42 AM   #10
Slowered318
Slowered318's Avatar
just get satalite radio.. reception is never good in any bmw i've owned
