Old 01-26-2005, 11:04 PM   #1
munichman
munichman's Avatar
Send a message via MSN to munichman
best way to mount subs in an E30
i'm sure this has been posted before but i dont have the ski compartment. I have heard that to avoid rattling the trunk they should be pointing to the front of the car.
munichman is offline   Reply With Quote
Old 01-27-2005, 03:42 AM   #2
Axxe
Over 9 F**KING THOUSAND!!
Axxe's Avatar
I have mine sitting in a box right in front of the ski pass through, and it still vibrates the rear license plate a bit. Put some weatherstrip underneath, and 250W is unleashed
Old 01-27-2005, 09:58 AM   #3
djtbster
R/C JUNKIE
djtbster's Avatar
Send a message via MSN to djtbster
well idk theres always gonne be thoose vents on the sides that will always flap, wen the subs around pounding, unless u close them shut or somting.
djtbster is offline   Reply With Quote
Old 01-27-2005, 08:48 PM   #4
ridr4lif
Send a message via AIM to ridr4lif
the best way to mount subs in a car like that is to mount them facing the back of the car. if you are worried about the trunk rattling then put some dynamat on the inside of the trunklid.
TEDD
ridr4lif is offline   Reply With Quote
Old 01-27-2005, 09:04 PM   #5
orionxtreme
the olny places the trunk rattles is:
licence plate (use rubber plumbing washers)
the plastic trunk lid jam (use thin foam weather stripping)
vents near bumper (this rattle is un-avoidable)
the jack and tools in the compartment
i dont' think dynamat will help that much unless you put it everywhere
orionxtreme is offline   Reply With Quote
Old 01-27-2005, 09:50 PM   #6
Check out Jordon's setup.
http://www.maxbimmer.com/forums/show...ht=port+tuning
Old 01-27-2005, 11:46 PM   #7
paul christians
87325is///MR.EVIL
T. Dot E30 that is fine but he dosnt have the ski hole like Jordon......so to do so you has to cut some holes in the metal behind the seat...........
Old 01-29-2005, 04:01 PM   #8
rayman
My 91 e30 did not have a ski hole but the metal panel was perforated where the ski hole goes. I punched out the panel and faced my two 10" subs forward. I then had the face of the box sealed to the metal panel so that the subs' soundwaves were forced into the interior of the car. Absolutely zero-rattling. Rattling is ghetto IMO. I initiially had subs facing the other way and it does seem to play a little lower. The effect is probably similar to "corner-loading" a sub in a home environment. But the entire trunk rattled. Much happier with subs facing forward.
rayman is offline   Reply With Quote
Old 01-30-2005, 03:03 AM   #9
munichman
munichman's Avatar
thanks guys
Old 02-01-2005, 09:53 PM   #10
munichman
munichman's Avatar
does anyone have some pictures they could put up?
Old 03-02-2005, 10:27 PM   #11
Griff
Check out my post here.
http://www.maxbimmer.com/forums/show...479#post563479
It works great, even without the pass through.
Phil Griffin
Toronto, Ontario
'86 325es
'85 VW GTI VR6
Griff is offline   Reply With Quote
Old 03-03-2005, 12:04 AM   #12
BMW BMXer
Wants a 350 Blazer.
BMW BMXer's Avatar
My setup is similar to Jordan's except sealed and I did it first.
Here.
http://www.cardomain.com/memberpage/420127/7
Stanceiseverything.com
Old 03-03-2005, 09:50 PM   #13
munichman
munichman's Avatar
very nice, great photo record of the restoration of your car too
Old 03-04-2005, 12:57 AM   #14
erik325i
if you don't have the ski hole you should cut one yourself. If you are going to spend your time and money installing a sub, you should do it right and port the back seat. Most e30s had the perforations for the ski hole which made it easy to simply punch it out. Since yours didn't come like that, you should cut a hole out yourself.
Point the subs to the rear of the car unless you only have one and it is mounted in the ski hole.
-Erik
erik325i is offline   Reply With Quote
Old 03-04-2005, 09:06 PM   #15
paul christians
87325is///MR.EVIL
I have the ski hole bout subs firing back...........
87is325///2.7L..EVIL.....
