Old 01-16-2005, 10:26 AM   #1
rodo
noobie question about sub installation
hey guys, one quick question, how hard would it be to install a sub in my aviator? if i got the sub and amplifier, how many wires would there be needing to connect and to where? also what would be the cheapest set up i could run? thanks
2010 328i
2010 Expedition
Objects in mirror are farther than they appear Only in a BMW
rodo is offline   Reply With Quote
Old 01-16-2005, 12:24 PM   #2
Jordan
You sound like the kind of person that should really just have a stereo shop install it for them.
Old 01-16-2005, 02:13 PM   #3
¤Mä®îؤ™
¤Mä®îؤ™'s Avatar
Send a message via MSN to ¤Mä®îؤ™
^^^ Agreed, it's not that expensice to get it installed either, it's better to get it installed correctly.
¤Mä®îؤ™ is offline   Reply With Quote
Old 01-16-2005, 05:06 PM   #4
rodo
so how much would it cost and how many wires to they have to connect etc cuz i dont want wires around my car or hte sub there all the time...
2010 328i
2010 Expedition
Old 01-16-2005, 05:17 PM   #5
Slowered318
12 wires
Old 01-24-2005, 06:23 PM   #6
JPWheelr
Kids play nice
You'll have 2 power wires, 1 remote turn on wire, and at least 1 signal wire - all going to the amp. There can be up to 4 depending on what the shop you use does, meaning they may need to add a line output converter to convert your factory signal to something the amplifier can understand, or they can go straight from there to the amplifier.
So far 4 - 7 wires that only go TO the amplifier, all can be hidden by a shop that does even half decent work.
From there, you'll need at least two wires going from the amplifier to the sub. Depending on the sub you get, or if you get a pair, this number can increase by multiples of two.
The cheapest setup depends on how crappy you want it to be. And you don't want wires around the car? Too bad, they usually have to route all over the place, but they can be hidden like factory. Removable sub w/ hidden wires? a lot of shops can do that also. For a simple subwoofer setup, done properly, you can spend on average about US$700 installed, add $$$ for removable or whatever else you want.
Jordan: "You sound like the kind of person that should really just have a stereo shop install it for them."
I couldn't agree more!
I strongly urge (insist) you don't try this yourself, or even watch the installers do it.
And make sure the installers are proffessionals, this doesn't seem like the right kind of vehicle for your buddy to learn on, or the local highschooler that thinks he's a pro should tackle. Real shop, real installers; you'll be glad you did.
Wires can be hidden, fires cannot.
I gave you a serious answer.
JPWheelr is offline   Reply With Quote
