Old 01-04-2005, 10:12 PM   #1
Betray
Send a message via ICQ to Betray Send a message via AIM to Betray Send a message via MSN to Betray
Oops I spilled soda on my controles
Well i opened a can of coke in my car while in its copholder and it managed to spray all in the side of the duel climate control. So now when i press the key it gets stuck lol. What ways can i go to cleaning this? I wanna avoid opening it up if i can.
Betray is offline   Reply With Quote
Old 01-04-2005, 11:40 PM   #2
SickFinga
SickFinga's Avatar
sell the car
Old 01-04-2005, 11:42 PM   #3
BMW_7
Econobimmer Racing
BMW_7's Avatar
why are you eating/drinking in the car, serves you right
Vitaliy
Old 01-04-2005, 11:45 PM   #4
King Luis
The King.
King Luis's Avatar
i was thinking about simple green but that might mess up the electronics.
i know there is something out there that you can use but i can't remember the name.
Mods: TBD.
Sold:2004 Silver Gray M3
Gone:1990 Brilliantrot 325is
Old 01-05-2005, 12:04 AM   #5
ZiMMie
take it apart and clean it. cant be that hard,
#E36-S54 #CSLWannabe
Old 01-05-2005, 12:20 AM   #6
Betray
cant be easy
Old 01-05-2005, 11:14 AM   #7
Paul540/m3
BMW Individual
Send a message via MSN to Paul540/m3
I did that on my steering wheel controls and they were sticky for a bit but the with more use it went back to normal
although im sure there is still some sticky shit there
Paul540/m3 is offline   Reply With Quote
Old 01-05-2005, 12:46 PM   #8
Miguel
...Delt Smash
Miguel's Avatar
1. turn on powerwasher
2. spray interior of your car
3. done.
Old 01-05-2005, 01:13 PM   #9
Adriano
Who's your daddy now?
Adriano's Avatar
Send a message via MSN to Adriano
Step #1 Go to Newfey Speed and Sport (Canadian Tire)
Step #2 Purchase electronics cleaner in spray can
Step #3 Shut off car and disconnect battery
Step #4 Spray on buttons where you gooked
Step #5 Connect battery and turn ignition on
Step #6 Pray that it still works
You can also get electroncs cleaner at Radio shack
The shit evaporates very quickly and doesn't leave any residue
Make sure you spray enough to dislodge the pop you sprayed- don't be a pussy, really get it in there.
Wait at least 1 minute before turning on power.
You can also squirt a little WD40 in there if you don't have any luck with cleaner at first, this will lubricate and remove most of the pop. Then remove the WD40 with the cleaner.
4 buttons on my E30 were stuck because some dick head spilt shit in there so I applied the above solution with great sucess.
Agent BMW trailer
Adriano is offline   Reply With Quote
Old 01-05-2005, 03:52 PM   #10
Betray
sounds all good, except #6. should i really be worried? and about the battery, do i really need to remove it?
Old 01-05-2005, 03:54 PM   #11
Justin e36
Justin e36's Avatar
go to radio shack and buy some contact cleaner.. (basically rubbing alcohol).. comes with a fine tip spray nozzel... use that to spray inside there.. soak it in good and press the button a few hundred times until it loosens up and keep spraying... don't worry, the electronics can't get enough of it. It won't ruin anything.. just make sure it dries properly. (only takes a few minutes to dry)
FYI -- it's not the liquid in the soda that is a problem for these electronics.. it's the sugar. That stickiness is all the sugar that has gunked everything up.
Old 01-05-2005, 03:56 PM   #12
Justin e36
Justin e36's Avatar
bah nevermind.. same thing adriano said. same product, different store... and he disconnects his battery because he's a pansy... real men like to electrocute things!
and no, you don't have to disconnect the battery.. you can take out the fuse instead... just press the buttons a few times to drain any remaining electricity from the unit.
Old 01-05-2005, 04:00 PM   #13
Gamite
Gamite's Avatar
www.gamite.net
Old 01-05-2005, 04:36 PM   #14
ara_yaz
Bimmer Fan
ara_yaz's Avatar
I had the same success with the above. I spilled a super-sized cup of ice-tea which fell on and from my dashboard, all over my center console, onto my heated seat switches, and filled up the accessory tray between the two seats (needless to say i was pretty pissed...damn Canabis-Sativa!). Anyways, as Justin e36 alluded to, it was the sugar that made it all sticky. I 'washed' my interior with contact cleaner and it did an awesome job. Don't worry, I use contact cleaner an all the insides of my electronics...it won't do any damage. It's great to get rid of dust which can cause crackling sounds when you turn an analog volume dial etc...
ethirty
ara_yaz is offline   Reply With Quote
Old 01-05-2005, 04:38 PM   #15
ara_yaz
Bimmer Fan
ara_yaz's Avatar
Hey Adriano, you have an e30?...pics?...rocket launchers?
ethirty
