Thread Tools Rating: Thread Rating: 3 votes, 5.00 average. Display Modes
Old 01-24-2005, 10:41 PM   #16
Gamite
Gamite's Avatar
Originally Posted by Antz_Marchin
No, the reason you overinflate during winter storage is for the most part because air contracts when it gets very cold, thereby decreasing the pressure in the tires. No real need to overdo things, you just want to compinsate for the decrease in air pressure when the air in the tires cools drastically.
That's not entirely true, your tires will only contract if the air around the tire is warmer than the air within the tire, thus there is more air pressure outside which presses inwards.
However, the air outside of the tire is pretty much the same temperature as the air inside the tire, thus the pressure levels have both dropped at the same rate.
I think most people over inflate just to eliminate flat spots because the tires sit on one spot for an extended period of time.
www.gamite.net
Old 01-25-2005, 12:49 PM   #17
bimmerod
The times that you would go for a spin you should be rolling your car a couple of feet in the garage so it is not resting on one spot on the tire.
Jackstands are bad because your suspension is now in a un-natural position. When you lower it, it'll actually be weaker than before.
Correct?
bimmerod is offline   Reply With Quote
Old 01-25-2005, 06:23 PM   #18
SpudBoy
Couped up
SpudBoy's Avatar
Send a message via ICQ to SpudBoy
Correct?
Jackstands allow you to remove your wheels and bag the brakes/calipers against rust. I don't think unloading your suspension can weaken it.
There is a great sticky post on winter storage around here somewhere.
SpudBoy
'99 M Coupe - Imola/Imola
Signature Pictures by Alezone
original BMW parts
To mod or not to mod? That is the question
SpudBoy is offline   Reply With Quote
