Thread Tools Rating: Thread Rating: 3 votes, 5.00 average. Display Modes
Old 12-26-2004, 11:32 AM   #1
E46coupe
E92 M3
E46coupe's Avatar
winter storage tire air pressure ???
i have 19's usually take the car around the block once a month. I overinflated to 45psi. Should i put more pressure???
Space Grey,Fox Red,DCT,EDC,Swift Springs,Carbon Fiber Roof,Diffuser,Splitters,Carbon Mirrors,M Performance Exhaust,ZCP Wheels,Caron Fiber Roof,15/12.5 spacers
E46coupe is offline   Reply With Quote
Old 12-26-2004, 02:15 PM   #2
Antz_Marchin
Antz_Marchin's Avatar
Id say that's plenty.......I have stock 17" M LTWs and overinflate from the usual 34/36 to 40 -41 all around. Make sure that if you take it out, it's more than just around the block. If you don't have a full temp run for about 15-20 minutes, the miosture that could condense in your engine at low temps to start won't evapourate and you'll be setting yourself up for internal rusting issues.
Antz_Marchin is offline   Reply With Quote
Old 12-26-2004, 02:21 PM   #3
E46coupe
E92 M3
E46coupe's Avatar
ok bud thanks for the info
Old 12-27-2004, 01:15 AM   #4
thinair
moderationistismingly
thinair's Avatar
I have my Toyo TS-1's at 55PSI. The labeled max tire pressure is 50PSI, so I figured an extra 5PSI wouldn't hurt, it's not like the car is moving.
Old 12-27-2004, 04:59 PM   #5
MorningCruiser
MorningCruiser's Avatar
You could probably fill them to 70PSI and not burst them...
Tires have a max pressure on them for a reason (usually maximum COLD pressures, meaning if it's -30, then you cannot exceed such pressures)...
The tires in a full size truck for example, max pressure is 60+PSI cold, you fill them to 60 at 5*c, and then get up to 100KM/h for 10 minutes, check the pressure and it'll be close to, or over 100psi.
Wheelman for hire - PM me for details - Any Police on the forum ignore this...
Originally posted by AlpWhitE46
"Im sickfinga, im always right."
MorningCruiser is offline   Reply With Quote
Old 12-27-2004, 05:01 PM   #6
E46coupe
E92 M3
E46coupe's Avatar
so do you think 50 is to little??
Old 12-27-2004, 05:38 PM   #7
Antz_Marchin
No, the reason you overinflate during winter storage is for the most part because air contracts when it gets very cold, thereby decreasing the pressure in the tires. No real need to overdo things, you just want to compinsate for the decrease in air pressure when the air in the tires cools drastically.
Old 12-27-2004, 08:19 PM   #8
E46coupe
E92 M3
E46coupe's Avatar
i just want to prevent flat spots.
Old 12-27-2004, 08:29 PM   #9
MorningCruiser
for the five minutes of effort required extra, use jackstands
Old 12-27-2004, 08:31 PM   #10
E46coupe
E92 M3
E46coupe's Avatar
i understand using jack stands but i take the car out once a month...
Old 12-27-2004, 08:35 PM   #11
MorningCruiser
like I said, it's an extra five minutes effort...
Old 12-27-2004, 11:35 PM   #12
mpower1226
mpower1226's Avatar
If you want to avoid the flat tire spots, just grab some shitty carpets and place under the tire.
Old 12-28-2004, 05:03 PM   #13
Antz_Marchin
Yup.............Thats what I have under all 4
Old 01-24-2005, 11:16 PM   #14
Bill P
If anyone's interested, I have some TireCradles that I want to sell off. There is a website at www.tirecrade.com if you want more info. If you are interested in picking up a set locally PM me for more details. I use my set all year round to prevent the tires on my E46 from flatspotting.
Bill P is offline   Reply With Quote
Old 01-24-2005, 11:37 PM   #15
E46coupe
E92 M3
E46coupe's Avatar
how much?
