Old 12-24-2004, 02:56 AM   #1
mecbain
18" weight
About how much should an 18" wheels with 225-40-18 tires on them should normally weight, I'm not talking about light rims here just a normal weight
mecbain is offline   Reply With Quote
Old 12-24-2004, 04:18 AM   #2
Mitch555
Retired MaXmember!
Mitch555's Avatar
What rim to be exact?
MY ENGINE SWAP: HERE!
Life Is A Tough Teacher, It Gives You The Test Then The Lesson.
Originally Posted by Mystikal
just do it once, do it right.
Mitch555 is offline   Reply With Quote
Old 12-24-2004, 04:20 AM   #3
mecbain
any 18" with tire size mentionned, just wondering what the average weight is to compare to mine....
Old 12-24-2004, 10:04 AM   #4
1BADRIDE
TECHGURU
Send a message via MSN to 1BADRIDE
It really depends on the rim. The range is quite large. I have seen as light as 17lbs all the way up to 42lbs.
2010 BMW 335D - Many mods to come!
1BADRIDE is offline   Reply With Quote
Old 12-24-2004, 12:48 PM   #5
Justin e36
Justin e36's Avatar
yes but he wants average.. which is around 23-25LB for the rim. Not sure about tire.
Old 12-24-2004, 12:59 PM   #6
GEEE$
Roughly 45-50 lbs for the combo...but tires alone usually weigh about 22ish.
A light 18 would be 20lb, a heavy set rim like a mom arrow will run close to 30.
G$
GEEE$ is offline   Reply With Quote
Old 12-24-2004, 01:12 PM   #7
45-50 is still pretty light. I'd say 48-56 is more "average" for an 18" wheel and tire. Width is a huge factor as well. My average is only up to around 8.5" wide.
Old 12-24-2004, 01:18 PM   #8
GEEE$
50 pounds for a 18" tire and wheel combo isn't light by any means, and yes, width is probably the biggest factor in determining the total weight.
The difference in weight between an 8" wide rim and a 10" wide rim is just HUGE.
G$
Old 12-24-2004, 05:49 PM   #9
mecbain
k thanks guys just weighted mine (rims + tires) and it's a little under 45lbs, so it's not as bad as I thought.
