Old 12-19-2004, 07:54 PM   #1
325isRED
325isRED's Avatar
Just In Time For The Arctic Weather...
This sucks...
I was freezing my ass off in my car as my heating was not working properly,
for some reason i cant get hot air to come through my front vents, there is little to no air blowing from the feet vents... and it just doesnt get hot enough when blowing through the defroster vents... any help????
someone once told me that there is a mechanical module that directs the air to where its supposed to go... could that be at fault, if so, how hard is it to replace?
PLEASE HELP ME!!!
Adam
Old 12-19-2004, 07:56 PM   #2
Justin e36
Justin e36's Avatar
what year is your car?
e36's don't have an electronic module to direct the flow of air.. (perhaps later model e36's do).. but early model rotary style climate control's don't. When you turn the knob you're actually moving the directional flaps behind the dash to move the air.
In either case, sounds like your microfilter might need changing...
Old 12-19-2004, 09:21 PM   #3
vinay
ya, microfilters can get quite blocked up over the years..
i changed mine out yesterday... didnt realize how small 3 series can be until i had to get under the dash!!
E90 DIY - E46 DIY - E36 DIY - E60 DIY - E30 DIY - E39 DIY - E34 DIY
"On My Command, Unleash Hell"
vinay is offline   Reply With Quote
Old 12-19-2004, 09:23 PM   #4
325isRED
325isRED's Avatar
its a 1992 with dual climate control... i'll check the microfilter.... but how does that explain the cold air coming out of the front vents??
Old 12-19-2004, 11:10 PM   #5
Miguel
...Delt Smash
Miguel's Avatar
you do yours yet?
Old 12-20-2004, 09:27 AM   #6
OILERS
your saying cold air is blowing through the vents. what is your thermostat reading. typical, it should be at the half way point once your car has warmed up and you've been driving for 5-10minutes. if it's below this and only a quarter of the way or less, your thermostat needs to be changed.
OILERS is offline   Reply With Quote
Old 12-20-2004, 10:33 AM   #7
Justin e36
Justin e36's Avatar
Originally Posted by Miguel
you do yours yet?
no time. ... wish I did though, sucks getting hardly any heat through on cold days like today.
Old 12-20-2004, 11:06 AM   #8
BRAD 82
BRAD 82's Avatar
Send a message via MSN to BRAD 82
how do you and where would you find the microfilter?
BRAD 82 is offline   Reply With Quote
Old 12-20-2004, 12:04 PM   #9
James325I
Microfilter.
I understand the microfilter is behind the dash on the passenger side. You will have to take the glovebox out. I have not done it myself but technicians who work on BMWs tell me its a real &*#@% to do. I'm sure theres a thread or someone here has done it before and will have suggestions and tips on how to do it. Good Luck.
The laws of physics are like any rules. Made to be broken.
James325I is offline   Reply With Quote
Old 12-20-2004, 08:51 PM   #10
325isRED
325isRED's Avatar
It blows hot air through the defrost vents and the floor vent, but if i switch it to the front vents, its hot at first, but then starts shooting cold after a few seconds. as for heating up... my car heats up normally.... and to make things worse... my heated seats arent working... the botton lights up, and it seems to get a bit warm... but not as hot as it should.
and the worst part... i can smell a little antifreeze when i first turn on the heater.... not a good sign i hear...
Old 12-22-2004, 12:14 AM   #11
MorningCruiser
MorningCruiser's Avatar
smelling antifreeze means the core is leaking...
If it stops after a bit, that means it's probably a seal being on the way out and the expanding metal stops it.
Wheelman for hire - PM me for details - Any Police on the forum ignore this...
Originally posted by AlpWhitE46
"Im sickfinga, im always right."
MorningCruiser is offline   Reply With Quote
Old 12-24-2004, 10:17 AM   #12
325isRED
325isRED's Avatar
^^^ it does stop after a bit... thanks cruiser...
