Old 11-15-2004, 10:09 AM   #1
shapez
Gearbox Problem
Hi All,
I'm having difficultly putting my e30 318is gearbox into an e30 316i car. The flange on the 318is gearbox is longer than the 316i. So, it won't fit on the 316i drive shaft.
I have tried to remove the flange from the 316i but I need an extremely thin walled socket. Even if I do remove it from the 316i gearbox I have an even harder job removing it from the 318is gearbox.
It's not looking good at the minute. I'm left with a couple of options..
1. Use a 316i gearbox on a 318is engine.
2. Replace the 316i drive shaft with a 318is drive shaft.
Help/Opinions/Advice is needed and much appreciated.
Cheers.
shapez is offline   Reply With Quote
Old 11-15-2004, 12:26 PM   #2
MR 325
R3VLimited.com
Send a message via AIM to MR 325
If you have the 318is driveshaft, I would just swap your 316 one for that.
MR 325 is offline   Reply With Quote
