Old 11-15-2004, 03:13 PM   #16
Lee in Ottawa
Lee in Ottawa's Avatar
post your reading then we can give you a more acurate diagnostic.
Lee in Ottawa is offline   Reply With Quote
Old 11-15-2004, 03:31 PM   #17
BMW BMXer
Wants a 350 Blazer.
BMW BMXer's Avatar
Originally Posted by Eurostyle
Its up to $400 now..
I did not have to pay 400. The emissions place didn't notice my exhaust leaking and therefore when I took it to one of my check up places the repair was more than 400 bucks so I got a conditional pass for the price of another test.
Stanceiseverything.com
Old 11-15-2004, 04:10 PM   #18
Deed
Good point. Here is the data:
40kmh Curb-Idle
Limit Reading Result Limit Rdng Result
HC PPM 109 76 PASS 300 34 PASS
CO% 0.61 0.59 PASS 1.5 0.11 PASS
NO ppm 1206 2392 FAIL NA NA NA
Sorry about the formatting - the board doesn't seem to allow multiple spaces...
I'm ready to go to Speedy or Cdn Tire unless anyone has better ideas. I just had Charlie tune it up and I am pretty sure he did the O2 sensor (can't recall, sorry, but I'll check). Definitely put in new plugs, did tune-up, etc.
Deed
Deed is offline   Reply With Quote
Old 11-15-2004, 04:47 PM   #19
"Charlie" should have tested the o2 sensor, not just replaced it. It either works or it doesn't. "Charlie" didn't do the timing, it's not adjustable. ??
You likely need a cat. You should really spend the $120 to get the diagnostic done to find out what you need. The labour $ counts towards the $450 limit. If you did an O2 sensor, that also counts towards it but you might have a hard time since you did it in the wrong order.
The shop needs to show that replacing the O2 sensor and the cat would make an improvement. To do that, they drill a small hole in the exhaust before the cat, and test pre-post. Then in the estimate to do the cat takes you over $450 dollars you get a conditional pass. The $120 and the O2 sensor, including labour, all count towards exceeding the $450 limit.
I got a conditional pass with a new O2 sensor for $340 bucks, including an oil change and the test / retest. The total emissions work was $270 and getting a cat would have been over $200 more with labour, which is over the $450, so I didn't have to get it done.
This year, anyway.
Old 11-15-2004, 05:58 PM   #20
Deed
OK, I know I am doing it all bass-ackwards. Here is how it happened!:
1. Sticker came due, so I needed an e-test.
2. Car was running a bit rough, so I figured a tune-up would improve my chances.
3. Got tune-up, replaced O2 sensor as it was gummed up with carbon, got new plugs, etc.
4. Thought I'd take a chance with a dodgy cc, but it should have been replaced.
Now I'm trying not to spend any more $$ than I have to! In fairness, the guy who tuned it up is working from his driveway right now so doesn't have a ton of resources at his disposal.
Deed
Old 11-15-2004, 08:54 PM   #21
Charlie is one of the best BMW mechanics in this area, so i would trust whatever he does...
You can get an E-test done under the table for $150-200, but you might spend less on just replacing the cat. Dont bring the car just anywhere, i know a very good place for E-tests, it very close to Charlie's, and my shop...Dixie & 401...
