Old 11-11-2004, 05:38 PM   #1
southcounty13
offset question
I am pretty sure this has been covered before but, could someone explain offset to me? I am looking to go from my current 17's to 18's what would be the correct offset?
southcounty13 is offline   Reply With Quote
Old 11-11-2004, 06:26 PM   #2
It's just the internet, don't be afraid to search it. Does anyone else ever have to research things for school and work? Anyways.
http://www.tirerack.com/wheels/tech/offset.htm
If you read that, you will understand that offset is independent of wheel diameter.
And if you want to know what offsets will work on your car, you have to first tell me the year of the car, suspension setup and wheel width. I'll tell you then what offsets and tire sizes you can run.
Old 11-11-2004, 07:31 PM   #3
southcounty13
Mystikal. I currently own a 1987 325ic. I am running 215/40/17x7. I want to go to 18x7.5. I also have adjustable air ride. What is your suggestion on offset if I want the tires to sit inside of the wheel well.
Old 11-11-2004, 09:46 PM   #4
Cabrio, so you have the lower arches. Air ride?! Never seen that on an E30, but okalie dokalie.
For a 7.5" wide wheel running 225/35/18, you'll want an offset in the range of ET23-ET27. The closer to ET25 the better.
For a 7.5" wide wheel running 215/35/18, you'll want an offset in the range of ET20-ET30. The closer to ET20 the better.
Try to get it in the ET23-27 range so you can run the 225/35/18 tire size. Juding from the air ride you don't push the car hard so the extra grip wouldn't really matter, but hey, it'll look better.
Good luck.
