Old 11-07-2004, 06:45 PM   #1
Lee in Ottawa
Lee in Ottawa's Avatar
HID help!! something very weird going on
K guys as some might know i've been trying to figure out this HID problem i've been having. I thought i had narrowed it down to one of the ballasts not working. So I figured before i gave up on them I'd try them out on my gf corolla to make sure. Anyways i plugged in the suspected ballast and sure enough it worked so i figured it must only not work on my car. Anywas my gfs dad liked them and i thought i'd show him what they look like with both in. So I hooked up the other ballast and turned them on. Sure enough the one i thought was broken wouldn't work but the other one did? In conclusion one of the ballasts works all the time no matter what but the other one only works when it's the only ballast plugged in and does'n't work when both are in. Anybody?
Lee in Ottawa is offline   Reply With Quote
Old 11-07-2004, 06:55 PM   #2
Betray
Send a message via ICQ to Betray Send a message via AIM to Betray Send a message via MSN to Betray
This is by far the strangest problem. When i was talking to you i told you about the DRL, but you said you tested it the way i did so it cant be that.. Anyone know if a E30 has enough power to start these things up? i have no idea, just trying to help him out.
Betray is offline   Reply With Quote
Old 11-07-2004, 07:06 PM   #3
Gamite
Gamite's Avatar
when you turn them on, do you turn them on at the same time with the car? Try turning them on after turning the car on? The ballasts need like 27000 volts to ignite the lights.
www.gamite.net
Old 11-07-2004, 07:11 PM   #4
Lee in Ottawa
ya i've tried tuning the lights on before i turn the car on like betray sugessted and them tried turning them on after the car is one and nothing. When i originally turn them on the one light that works goes extremely bright for a sec them goes normal. I've ruled out a problem with my car cause i just tried them on a brand new corolla and same thing.
Old 11-07-2004, 07:27 PM   #5
Gamite
Gamite's Avatar
that's really really weird.. I'd understand if only one didn't work consistantly..
www.gamite.net
Old 11-07-2004, 07:33 PM   #6
Lee in Ottawa
ya i know. One always works no matter what and this other one will only work when it's the only HID hooked up. I just tried turnig the lights on everyway possible. car on then lights on/ lights off then car on/ daytime on then car on then lights on etc everypossible way. still only the same one light works. It's a e34 btw with projectors if it makes a difference.
Old 11-07-2004, 07:50 PM   #7
Gamite
Gamite's Avatar
where are you placing the ballasts? I'm sure it probaby has nothing to do with it, but maybe its being grounded somewhere.
www.gamite.net
Old 11-07-2004, 07:55 PM   #8
Lee in Ottawa
i havn't drilled them in yet. There lying up near the shock towers out of the way. There is double sided tape left on them from when betray used them. Should i be srewing them into somewhere for them to work? Are they not grounded through a ground wire in one of the connections?
Old 11-07-2004, 10:04 PM   #9
Gamite
Gamite's Avatar
should be okay, I didn't drill mine in, just stuck them on with tape.
www.gamite.net
Old 11-07-2004, 10:08 PM   #10
Lee in Ottawa
I give up, there not working i've tried everything and no good.
Old 11-07-2004, 10:14 PM   #11
Gamite
Gamite's Avatar
are you sure you didn't get the two ballasts mixed up and its just the one that's not working?
www.gamite.net
Old 11-07-2004, 10:34 PM   #12
Lee in Ottawa
oh i know it's on;y one thats no good. one works fine. It's just one only works byitself. the when u plug the good on in it stops working. how does it know the other one is plugged in?
Old 11-07-2004, 10:44 PM   #13
Gamite
Gamite's Avatar
hm, no idea, u sure the two prongs are wired in correctly? The two prongs that go into the plug?
www.gamite.net
Old 11-07-2004, 10:57 PM   #14
Lee in Ottawa
yep everything is good no bad looking connections
Old 11-07-2004, 11:01 PM   #15
ZiMMie
try splittin the wires. maybe some of the connectors have rust in them.
#E36-S54 #CSLWannabe
