Go Back   maXbimmer Forums > Classifieds > For Sale > Suspension & Brakes
Old 10-16-2004, 06:14 PM   #1
Autotechnica
Little Chino
E36 M3 Hartge Suspension for trade.
Looking to swap Hartge Suspension for stock M3 suspension.
Includes
Hartge springs
Hartge front and rear dampers
Hartge front and rear adjustable sway bars
Parts are from a '94 Eurospec M3, less than 2 years old.
Selling for a friend, he is asking $1000 + trade.
Bry
Old 10-16-2004, 09:44 PM   #2
ClayMan
Do you have the specs on those sways? Are they strut or control arm mounted? How thick?
Includes
Hartge springs
Bry
ClayMan is offline   Reply With Quote
Old 10-16-2004, 09:46 PM   #3
Autotechnica
Little Chino
Don't have the specs, but you can check them out if you want. It's mounted on the car. Strut mounted, it's from an M3 remember?
Old 10-19-2004, 03:05 PM   #4
Autotechnica
Little Chino
30mm front, 24mm rear. Those are approximate figures.
Old 10-19-2004, 03:06 PM   #5
Autotechnica
Little Chino
Welcomming all offers. Need this swap done this week!
Trade for stock M3 suspension, springs, dampers, sways.
Hartge full suspension suspension purchased from Raven.
Old 10-19-2004, 07:37 PM   #6
ClayMan
30mm front? That's huge! Doesn't that understeer like mad?? (unless it's control arm-mounted...)
Old 10-19-2004, 08:04 PM   #7
Autotechnica
Little Chino
It's not huge for an M3. Keep in mind these are approximate measurements. It's still on the car! We just measured it using a measuring tape. Plus, you can't really compare sway bars directly, because a lot of them are designed differently than OEM ones which means the thicknesses are negligable. 24mm in the rear is also huge, so it pretty much balances out. You'll just have a very hard riding suspension.
That's the whole point of having them adjustable.
Old 10-19-2004, 09:45 PM   #8
ClayMan
So they are adjustable then? How do they ride/handle?
Stock M3 is 23mm/20mm (front/rear) and is already tuned for understeer, which is why I was a little shocked when I read that the front is larger by 7mm and the rear by 4mm... (Of course I do not know how adjustable they are)
Old 10-19-2004, 09:51 PM   #9
Autotechnica
Little Chino
My current sway bars are 28mm front and 21mm rear. I still get oversteer. So like I said before the thickness of the sway doesn't mean anything because they aren't the same shape/material as the OEM sway bars. You can only compare them if the aftermarket sway bar is the same shape and material as the OEM bar.
If you are really interested. Call me and we can arrange a time for you to look at them and even try them if possible.
Bry
