Old 09-20-2004, 12:10 AM   #1
nseverin
nseverin's Avatar
Heated Seats
My passenger seat heat doesn't work anymore.
when you push the button. both LED's just flicker.
Any quick fixes out there?
nseverin is offline   Reply With Quote
Old 09-20-2004, 01:59 AM   #2
E36er
West Coast Contact!
E36er's Avatar
well mine stopped working..and it just ended up being the switch...i got a new switch and it worked perfect...try switching the Drivers seat switch with the passengers...thats my trouble shoot...could be more complex though
E36er is offline   Reply With Quote
Old 09-20-2004, 04:48 AM   #3
Justin e36
Justin e36's Avatar
try e36ers advice first. if it still doesn't work, let us know.
Old 09-21-2004, 12:47 PM   #4
OILERS
nseverin, don't mean to steal your thread. but my drivers seat heat doesn't work either. when i hit the switch, it lights up on low and high, just no heat. the passenger side works fine. i know it could be a bunch of things, any ideas, or maybe quick fixes.
OILERS is offline   Reply With Quote
Old 09-21-2004, 12:48 PM   #5
Justin e36
Justin e36's Avatar
if you don't feel heat on your back AND bottom then it's probably a loose wire, or the plug for the heating elements came out.
Old 09-21-2004, 04:45 PM   #6
nseverin
nseverin's Avatar
lucky you. both led's flash!
check your heat fuse. I forget which one it is. I believe its in the 50's
Old 09-21-2004, 08:53 PM   #7
OILERS
thanks justine36 and nseverin, i'll check it out.
