Old 07-02-2002, 09:01 PM   #1
Jon@Bimmersport
Jon@Bimmersport's Avatar
Flash 5
is any1 here good with Flash 5?
Old 07-04-2002, 09:37 AM   #2
Razkal
Razkal's Avatar
what do you want to know?
Rides:
08 SG/FR BMW M3 E90 sedan
11 White BMW X3
Need any assistance branding your company/services? :
http://www.bluemouse.ca
__________________________
Razkal is offline   Reply With Quote
Old 07-04-2002, 11:44 AM   #3
Jon@Bimmersport
i tried to make my link fade in, but when i play it it doesnt do it...but when i move through frames manually it does..why does it do this?
Old 07-04-2002, 01:13 PM   #4
Razkal
Razkal's Avatar
you have to make your link an image so that u can tween it from the faded state to the original one...
Rides:
11 White BMW X3
Old 07-04-2002, 01:17 PM   #5
Jon@Bimmersport
i dont get it...k this is wat i did...i typed in the words, then put the alpha down to zero, right clicked the frame and kep adding keyframes, and in each frame i raised the alpha...isnt this the correct way too?
Old 07-04-2002, 03:37 PM   #6
Razkal
Razkal's Avatar
if you are going to change something, it needs to be an image.
So:
type whatever you want
select it and hit F8
convert it to symbol
then CTRL + L brings up the library
then drag it to the stage
and do what ya like with it
if you need Flash help, go to flashkit.com
Rides:
11 White BMW X3
Old 07-04-2002, 04:52 PM   #7
Jon@Bimmersport
kool thanx man
