Old 07-28-2004, 08:42 AM   #1
nseverin
nseverin's Avatar
Brake Pad Light.
On Saturday after some hard driving my brake pad light came on. I knew I needed some front pads soon cause I could see them through the rims. Anyways, I replaced the pads, rotors, and sensor. The backs are still good.
Does this light go out on its own or do I need a reset.
Help.
nseverin is offline   Reply With Quote
Old 07-28-2004, 08:51 AM   #2
Quack
Wheelman
Quack's Avatar
the light turns on because the brake wear sensor is touching the rotors, once you replace everthing, the sensor is no longer touching the rotor and the light should be off, if the light is still on make sure the wire of the sensor isn't rubbing against the rim, also check your brake fluid level
Old 07-28-2004, 12:23 PM   #3
Harry
I think that with BMW's, once the sensor is tripped it needs to be replaced. They're like $20 or something at the dealer. The sensor wears down with the pad .
Harry is offline   Reply With Quote
Old 07-28-2004, 12:55 PM   #4
cwiniarz
^^ that's what i thought
cwiniarz is offline   Reply With Quote
Old 07-28-2004, 01:56 PM   #5
Quack
Wheelman
Quack's Avatar
that is true, but some people like to save some money, unless the sensor is completely worn out then you must buy one, once any part of the sensor touches anything metallic the light will turn on
Old 07-28-2004, 02:09 PM   #6
Jon@Bimmersport
Jon@Bimmersport's Avatar
when u get brakes serviced at the dealer, i think they just replace the sensor, well i remember from benz they use new hardware for everything
Old 07-28-2004, 02:11 PM   #7
Quack
Wheelman
Quack's Avatar
Jon you are also correct, but we also replace things even when they don't need replacing at Benz, that's where all the money comes from
Old 07-28-2004, 02:17 PM   #8
koncise
all you need is one mike
koncise's Avatar
Send a message via MSN to koncise
just cut the wires, twist them 2 together, and tape it up.... no more brake pad light
koncise is offline   Reply With Quote
Old 07-28-2004, 02:35 PM   #9
nseverin
nseverin's Avatar
Talking
lol
you guys are too much!!!!!!!
Anyways I put a new sensor and talked to my friend whos a Bimmer Mechanic and he told me to turn the ignition key on (don't start the engine) for 30 sec. and it will go out. Well he was right!
Old 07-28-2004, 02:36 PM   #10
koncise
koncise's Avatar
I was serious
Old 07-28-2004, 02:37 PM   #11
nseverin
nseverin's Avatar
Me too!
I still want my sensor to work ya know!!!
lol!!
Too much. Thats what I used to do back in day!
Old 07-28-2004, 11:20 PM   #12
V-Thang
yea i would just cut it... not that important to have a pad sensor...
V-Thang is offline   Reply With Quote
