Old 07-27-2004, 02:30 AM   #1
PBalla
PBalla's Avatar
Plz help me start my car
Well..after this
I turn the car on, only SOME of the lights turn on to check...
PARK BRAKE
BRAKE LINING
BRAKE
ANTI LOCK
BATTERY
OIL
it used to be that they would all turn on, and all turn off when i started the car...now, the Brake, anti-lock and battery stay off, UNTIL I turn the car on, then (and sometimes this happens with the PARK BRAKE)...they stay lit, and when my RPMs rise, they dim, but when I go to neutral and fall below 1000 RPM (eta) they get lit (not to full), and my brake lining is always on just cuz sensor is loose or something. I talked to a friend he said it was normal due to the use of the alternator, and I had thought about that myself, but then why didn't it happen before, cuz its not normal.
But the car runs fine, just having those lights on, sometimes gets me worried.
ANyone experience this?..should I not worry?
In short, warning lights on when they should be off.
my car has just died on me...i start the car and i went for a bit and then i noticed lights were flickering, headlights dimming, and i could barely turn the wheel...now i try to start it..lights turn on but when i try to ignite everything goes dead
Now, I just got my battery replaced brand new 2 months ago AND my alternator..so what happened?
any advice is appreciated..btw, the car used to leak a lot of oil, my mechanica checked it out, and fixed it..but now it leaks a tiny amount, real small.
PBalla is offline   Reply With Quote
Old 07-27-2004, 02:44 AM   #2
SpoolinS6
SpoolinS6's Avatar
did u see if the belts in place
or if the belt is slipping due to all that oil on the belt itself ?
2000 Jetta tdi Bagged
1995 Audi S6
HI BOOST
Old 07-27-2004, 03:57 AM   #3
PBalla
PBalla's Avatar
i will check
Old 07-28-2004, 02:25 PM   #4
PBalla
PBalla's Avatar
jump starting worked
but tehn i tried it on my own
no go
HELP ME
Old 07-28-2004, 02:47 PM   #5
crusher
OMGHI2U2
crusher's Avatar
are you sure your alternator is charging your battery?!? check your battery
2013 Ford Focus SE
2011 Lincoln MKT
2003 Escalade 8 Seater of Fun - 251k and still running
Sold/Traded-in
2006 M5
2003 M3
2003 Civic Si
2000 M Coupe
1999 M3
1999 323i
crusher is offline   Reply With Quote
Old 07-28-2004, 05:05 PM   #6
PBalla
PBalla's Avatar
ok, called mechanic, he said it can't be start or alternator...he said to clean my ends on the battery and try to start..then try volt meter
