Old 07-20-2004, 10:53 PM   #1
jordan325
jordan325's Avatar
How much oil should our e30s burn?
Mine uses about 1 litre every 3000 KM?
Anyone?
[FONT="Arial"] e90 323i
jordan325 is offline   Reply With Quote
Old 07-20-2004, 11:09 PM   #2
umm none, buring oil aint a good sign man
Old 07-20-2004, 11:17 PM   #3
AmaRu
AmaRu's Avatar
Re: How much oil should our e30s burn?
/_____l_________l_____\
[___[']==(\X/)==[']___]
\__l_l-[-------------]-l_l__/
\____________________/
AmaRu is offline   Reply With Quote
Old 07-20-2004, 11:30 PM   #4
Jordan
Old 07-20-2004, 11:49 PM   #5
Chris de la Cruz
sex, drifting & punk rock
www.CSCS.ca
Old 07-20-2004, 11:53 PM   #6
BMW_M52_M20
Anyone?
I guess you probably would have seen, but you aren't leaking any over a slow period time? Valve Cover Gasket? Cam seals? Oil Pan gasket? Leaky heli coil?
Most likely sounds like you may be burning oil, but you should check other options.
Past: 1998 323is (E36)
1986 325e (E30)
Present: 1997 Jetta GLX VR6
2004 325iT (E46) (pops)
Old 07-21-2004, 09:42 AM   #7
chromius
chromius's Avatar
over time, your valve guides and piston rings will start to wear out, then you will start to burn oil...
How many km's on your car?
I would say 1 liter every 3000-5000 km is not anything to really worry about.
Old 07-21-2004, 10:16 AM   #8
jordan325
jordan325's Avatar
Oh yeah, it leak oil. It's my oil pain gasket i think. I pass emissions fine and there is no blue smoke coming out of the tail pipe.
Also in our Bentley manual in Section 4 Engine on page 7, it says " Some oil consumption is normal and indicates healthy flow and distribution of the vital lubricant in the engine. BMW states that the maximum allowable oil consumption for the engines covered in the manual is 1 quart per 390 miles."
Thats crazy, 1 quart 390 miles? That is like 1 litre every 800KM.
Old 07-21-2004, 10:24 AM   #9
AmaRu
AmaRu's Avatar
mayb ur using the wrong oil? i know my e30 burns synthetic oil
Old 07-21-2004, 10:26 AM   #10
jordan325
jordan325's Avatar
maybe, I use Castrol oil in it, non synthetic. The guy I bought it from said it didn't burn any oil, maybe he used something different.
Old 07-21-2004, 11:02 AM   #11
BMW_M52_M20
I use Castrol GTX 20W50 in mine, don't burn a drop.
1986 325e (E30)
Old 07-21-2004, 12:43 PM   #12
BMWE30
Send a message via AIM to BMWE30
Burning some oil is normal....and I mean some (very minimal)...even new cars do it. This is especially true with a cold engine when the metal is cold and isn't expanded. Also, higher mileage engines have some wear...this will cause a little oil to get by too. Nothing to worry about....unless your consuming large amounts of it that is.
Vincent Esser
1987 325 2 door
Too many mods to list
BMWE30 is offline   Reply With Quote
Old 07-21-2004, 12:58 PM   #13
jordan325
jordan325's Avatar
yeah, I use 20w50 Castrol as well. My 325 has 415,868 Km on it
Old 07-21-2004, 01:05 PM   #14
chromius
chromius's Avatar
415,868km and its only burning 1 liter per 3000km...damn I'd be happy with that.
Old 07-21-2004, 01:15 PM   #15
punnzzells
punnzzells's Avatar
Send a message via MSN to punnzzells Send a message via Yahoo to punnzzells
best oil
that seems to be the best oil for E30's.... my car feels great when I have that oil in it...
punnzzells is offline   Reply With Quote
