Old 07-19-2004, 08:32 PM   #1
jeremy
Question what's needed to fit an s50 into a 318ti
like it says....what changes are needed to fit an s50 motor into a 318ti ? say the motor is from a 1995 m3 and the 318ti is a 95 also...is it pretty much a straight drop in ? would you be able to take an s50 that has all the appropriate changes to fit into an e30 and drop it into the 318ti ? any insight would be grrreat
thanks
Old 07-19-2004, 08:33 PM   #2
Lennon
Send a message via ICQ to Lennon Send a message via MSN to Lennon
Sorry I have no answers... Jeremy. What ARE you doing? Do I smell a new project?
I call dibs on your car!
1990 735iL under construction.....
Lennon is offline   Reply With Quote
Old 07-19-2004, 08:34 PM   #3
jeremy
ok....i have a "friend" who is thinking of buying a 318ti and dropping his s50 in it....
Old 07-19-2004, 08:39 PM   #4
Lennon
Riiiiiiiiight. Gotcha.
Old 07-19-2004, 10:14 PM   #5
NickP
NickP's Avatar
If you have an e34 oil pan you'll need to switch back
Old 07-20-2004, 08:00 AM   #6
jeremy
poo...i sold the m3 oil pan...
what about motor mounts ?
i know the comp situation is fine...
Old 07-20-2004, 09:33 AM   #7
M3ti Compact
Fuel Efficient 318 Member
M3ti Compact's Avatar
the 318ti is the same as the 318i sedan from the bumper to a-pillar. So anyone who has swapped out their 4-banger would be able to help you out.
M3ti Compact is online now   Reply With Quote
Old 07-20-2004, 02:44 PM   #8
NickP
NickP's Avatar
Motor mount arms are the ones you're using now, you'll want the e36 mounts... PS I have the pan if you need it.
Old 07-20-2004, 02:49 PM   #9
jeremy
how much for the pan ? was the pan origanly from an m3 ?
i still have the m3 pick up and dipstick and all that shit....
Old 07-22-2004, 03:04 AM   #10
BMWF1
Guest
Posts: n/a
90hp ain't cuttin it anymore???
Old 07-22-2004, 09:44 AM   #11
SkycityBMW
SkycityBMW's Avatar
LMAO . . . .
SkycityBMW is offline   Reply With Quote
Old 07-22-2004, 10:19 AM   #12
ChahalzBMR
You will have change the engine mount, power steering lines, rad, some a/c components, transmission and the read end (if u don't want to be reving high all time)
who told you the computer would be fine? You will need to change the computer too...
it's not a straight drop.
91' CRX Turbo - Sold
94' 318i/M50 swap - Sold
95' 325i - Sold
97' Jetta - Sold
2006 Ford Freestyle - Sold
Looking for a E46 (00-04)
Steve
ChahalzBMR is offline   Reply With Quote
Old 07-22-2004, 11:10 AM   #13
jeremy
uh i did....why wouldnt a 95 m3 ecu and wirring harness work ??? both are obdI cars ?
Old 07-22-2004, 11:11 AM   #14
jeremy
what are you talking about ?? i have a s50e30....i dont own a 318ti...i was thinking of buying one and dropping my s50 in it ...
