Old 07-13-2004, 09:50 PM   #1
E46
Cleaning Calipers / Brake Dust
Anyone know where i can get the strongest cleaning solution to get the brake dust thats pretty much stuck onto my calipers?
I dont want weak stuff that protects clear coats on wheels. The calipers arent on my car right now so im looking for the strongest stuff that will take all the brake dust off. Thanks
2002 325Xi Sport Wagon
www.europrojektz.com - Europrojektz Northwest
E46 is offline   Reply With Quote
Old 07-13-2004, 10:01 PM   #2
cwiniarz
Meguires hot rims works good on rims with a lot of break dust you could try that (just spray and rince). if not try autosol it's in a tube you can find it a canadian tire, all you do is apply and rub, works like a chram on all metals, it also remove oxidization and other contaniments on metals
cwiniarz is offline   Reply With Quote
Old 07-14-2004, 01:23 AM   #3
Lip
rub it with steal wool + chemicals (eg. rim cleaners)
Lip is offline   Reply With Quote
Old 07-14-2004, 02:05 AM   #4
Jordan
Disassemble the calipers, have them bead blasted, pick a color and have them powdercoated, then reassemble them with all new seals. They will look and work better then new.
Old 07-14-2004, 02:53 AM   #5
Gamite
Gamite's Avatar
Great stuff! I use it all the time, takes off everything, but is safe for the clear coat.
Do NOT use steel wool, it will scratch your clear coat on your wheels.
www.gamite.net
Old 07-14-2004, 08:54 AM   #6
Sunapollo
he's cleaning the caliper so steel wool is fine !
Sunapollo is offline   Reply With Quote
Old 07-14-2004, 08:57 AM   #7
cwiniarz
^^^ YUp steel wool and good rim cleaner will work awsome,
Old 07-14-2004, 10:14 AM   #8
SkycityBMW
SkycityBMW's Avatar
Use "Westleys Bleche-Wite" I used it to clean my rims that had alot of built up brake dust on the rims. A little elbow grease should do the trick.
Good Luck ! ! !
SkycityBMW is offline   Reply With Quote
Old 07-14-2004, 08:28 PM   #9
Gamite
Gamite's Avatar
oops misread topic.
www.gamite.net
Old 07-14-2004, 08:39 PM   #10
bmwboy88
When I bought my car, the salesguy gave me a bottle of rim cleaner from BMW. That stuff is strong sh** as I only use it when my wheels get all black. A couple spray, wait for a few secs and spray water, the rims looks like new.
sorry, don't know the name. It's OEM
BMW = ULTIMATE DRIVING SENSATION
bmwboy88 is offline   Reply With Quote
