Old 07-06-2004, 11:25 PM   #1
BladeRunner
BladeRunner's Avatar
How many of you BMW owners actually do tire rotation?
Yesterday my dad suggested that I rotate my (4 month old) tires, well because he rotated his tires that same day.
I replied it was not completely necessary for me to rotate my tires because, "BMW does not recommend tire rotation. Owning to the car's suspension design, the front tires begin to wear first at the outer shoulder and the rear tires begin to wear first at the middle of the tread or inner shoulder. Rotating tires may adversly affect road handling and tire grip.
NOTE -- The main purpose of tire rotation is to promote even wear and maximum tire life. Tire life may be decreased slightly if the tires are not rotated" (Bentley Publishers).
By the way, my dad drives a Ford so his suspension is independent to some degree and has more postive camber than mine.
Mad E30 lover
BladeRunner is offline   Reply With Quote
Old 07-06-2004, 11:30 PM   #2
Quack
Wheelman
Quack's Avatar
I don't rotate my tires, my front tires wear out pretty evenly, my rear tires wear out fast due to my lead foot, this also means I only have to buy 2 tires every now & then
Old 07-07-2004, 12:46 AM   #3
e30 dude
my e30 manual actually says not to rotate the tires.. doesn't say why though.
e30 dude is offline   Reply With Quote
Old 07-07-2004, 12:48 AM   #4
crazyvadim
crazyvadim's Avatar
I dont rotate my tires,just like Quack i have a lead foot so my rears have to be changed very often.I also heard i remeber from a BMW tech that you shouldnt rotate your tires on an M5.
Old 07-07-2004, 01:58 AM   #5
The rear wheels are wider so are the tires, i dont think u wanna rotate those
Old 07-07-2004, 08:49 AM   #6
I just did a front-rear swap after like 4000km, I'm trying to get the best out of a 200 rated treadwear tire.
And screw that BMW recommends crap, with the way I drive they are worn to the new alignment settings within an hour.
Old 07-07-2004, 08:51 AM   #7
Surk
6 Spd Member
Being in the carbiz...tire rotation is an essential service... Even though they wear differently on BMW's F>R... I would recommend roation regardless ONLY if they are not staggered sizes... I rotate my summer 18's more frequently (twice a summer) and have had no issues with handling or steering. This will maximize your tire investment and offset camber wear. IMOA
Supersprint V2 headers & Midpipe--Agency Power Muffler- Bilstein PSS9 coilovers-Radernergie R-10 wheels--Bimmerworld\BMC filter Intake--Mark'D Custom CSL software--Rogue SSK--Rotora drilled brakes\StopTech pads
Surk is offline   Reply With Quote
Old 07-07-2004, 08:52 AM   #8
Heh, it's not really a problem if your camber is equal front-rear like mine. Oversteer rules.
Old 07-07-2004, 09:26 AM   #9
thinair
moderationistismingly
thinair's Avatar
I rotate my tires all the time, especialy if I have been doing some creative driving. My tires wear in the same place, but the rear just wears a little faster. I rotate my tires aftert every autox or track day.
Keeping in mind my camber angles, tire and rim sizes are the same from front to back also. I don´t rotate from side to side because my tires are directional
Old 07-07-2004, 09:33 AM   #10
jmalixi
I rotate tires on all the cars I've had and I've owned different makes. My main reason for rotating, aside from longer tire life, is that I don't like buying two tires at a time. It's like getting only a partial benefit of having new tires.
So far, I have not had any issues with rotating tires. I refuse to blindly follow a recommendation, even it's from BMW, that doesn't have any merit. BMW is probably just trying to avoid getting sued in case some stupid person rotates tires on a staggered setup.
jmalixi is offline   Reply With Quote
