Old 06-09-2004, 05:48 AM   #1
jj0n
Is It Worth It?
Hi,
I want to purchase this 1999 328i that I have seen; it has 74,500km, heated sports seats, 5sp man, sunroof, 17" rims with new tires, cd changer. -see pic
THE PROBLEM
These problems showed up on the pre-purchase inspection by CAA:
1. Exhaust leak at front hanger (the pipe showed little to no rust) (needed for safety)
2. Front struts are weak and leaking
3. Front breaks pulsate (moderate)
3. Recommended 4 wheel alighment
4. Power Stering Belt is cracked (fix needed for safety)
5. Shampoo and recheck for oil leaks
Today the seller said the a/c would not blow cold air even though he got it reciently recharged and the compressor seems to be working (>rpm when engaged)
THE QUESTION
is this car worth $22000 safeted with the a/c fixed????????
the price seems good even with the above concerns,
what do you guys think??
jj0n is offline   Reply With Quote
Old 06-09-2004, 10:16 PM   #2
jj0n
Anyone?
Old 06-09-2004, 10:30 PM   #3
Paul540/m3
BMW Individual
Send a message via MSN to Paul540/m3
maybe check trader.ca and see what else is available
and factor in all repair costs and that is what the car will REALLY cost u
Paul540/m3 is offline   Reply With Quote
Old 06-22-2004, 11:16 AM   #4
jmalixi
I think it's still a good deal.
If you're planning on modifying the car later on, this is the perfect time to:
- lower the car with a new set of springs and shocks/struts
- install new rotors/pads
- install a better sounding exhaust
- power pulleys since they require new belt anyway
You can probably do all that for $5K (or much less if you shop around properly for used parts), bringing your car to $27K (or less) nicely modded already. Some of us have to replace perfectly good parts to get our cars modded up. At least you won't be wasting any.
jmalixi is offline   Reply With Quote
Old 06-25-2004, 09:45 AM   #5
Surk
6 Spd Member
328i
I bought my 99 328i sport for $24000 wholesale with 69k (being in the carbiz) and had to do some stuff to it also for safety. It's still a good deal as they are retailing for $24-25,000 range with more kms... try to use the faults as a leverage tool (especially the AC as this can be expen$ive to repair on a BMW)
Supersprint V2 headers & Midpipe--Agency Power Muffler- Bilstein PSS9 coilovers-Radernergie R-10 wheels--Bimmerworld\BMC filter Intake--Mark'D Custom CSL software--Rogue SSK--Rotora drilled brakes\StopTech pads
Surk is offline   Reply With Quote
Old 07-09-2004, 06:42 PM   #6
jj0n
Hi and thanks for the replies to my first posting on this site!,
I ended up getting the car below: 1999 323i spt pkg, 5spd, koni shocks, H&R springs, RD frt bmper, new brake pads & rotors, pioneer premier sterero + amp, clifford alrm, dinan software, and
61,500 km = for $22,200. Has no leaks or sign of corrosion underneath. Have had a few problems with the alrm (not all features working), and stereo alternator noise. The chk engine light came on 2 days after I got it, but no change in how it runs - which is great!!
I think that it was a better deal than the 328i even though the engine is smaller. What does anyone think?
Does anyone know of a good place to get the engine light seen to who will give me a good deal? (I live in hamilton and work in north york).
Cheers!
JK
Old 07-09-2004, 07:10 PM   #7
golden
Doesn't have a car.
golden's Avatar
congrats man
now get some clears!
02' 325CI
golden is offline   Reply With Quote
Old 07-09-2004, 07:12 PM   #8
jj0n
engine
just cleaned!
Old 07-09-2004, 07:13 PM   #9
jj0n
thanks!
Should I get them from a bmw dealer?
Old 07-09-2004, 08:31 PM   #10
jmalixi
Re: thanks!
It's probably close to $500 if you get them from the dealer. Check your PM.
Old 07-09-2004, 08:55 PM   #11
SpudBoy
Couped up
SpudBoy's Avatar
Send a message via ICQ to SpudBoy
mmmmmmmmmm alpine white
SpudBoy
'99 M Coupe - Imola/Imola
Signature Pictures by Alezone
original BMW parts
To mod or not to mod? That is the question
SpudBoy is offline   Reply With Quote
Old 07-12-2004, 08:27 AM   #12
EricE330ci
Looks great jj0n. Alpine white looks great modded
2001 330ci / SP / HK / OEM Clears / OEM Eurotray / OEM M3 Steering Wheel / DIY Silvervisions
19" Hamann HM2's / 235/35ZR19 Yokohama AVS / ECIS CAI / JTD RSM / PSS9 Coilovers
M-Tech Package / PIAA Xtreme White fogs / 32% Tint / Zaino Polish / Umnitza Angel Eyes
EricE330ci is offline   Reply With Quote
