06-09-2004, 04:49 AM
#1
Car: 13 Optima Turbo Demo
e21 starting problem.
my sisters 81 320i will crank but not start. Any ideas? plugs are good, distributor cap and rotor are new.
06-09-2004, 03:36 PM
#2
the misanthropist
Car: '05 4Runner, 87 325
*takes deep breath*
afm,fuel pump,fuel filter,fuel pump relay,main relay,old gas,coil,dme,crank position sensor,broken timing belt, bent valves...low fuel?
06-09-2004, 03:56 PM
#3
Originally posted by BigD
*takes deep breath*
thanks man, i thought of fuel pump and the relay, gas is good, its a timing chain not a belt, so coil, crank position sensor. ok a few things to check thanks!
06-09-2004, 10:13 PM
#4
yep its fuel pump....used one on its way and sister might actually tackle it herself before Dad gets home from California.
06-09-2004, 10:31 PM
#5
Car: BMW
oh i had this problem before!! i removed the fuse box cover to change a light fuse, then when i put the cover back, i accidently moved a fuse out of its place, i forgot which one, but take a look at the fuse box, hopefully that should do it!!
06-09-2004, 10:40 PM
#6
ya I got her to check that, she said it all looks good. thanks for the idea though
