Old 06-02-2004, 11:38 PM   #1
SickFinga
SickFinga's Avatar
Foglight burn out the fuse. WHY???
When I turn on my foglight, my fuse burns out right away.
I though it was the bulbs, i changed them - same thing.
Then I disconnected left fog housing, right one worked
connected left one, disconnected right one - worked
but when they are both on, fuse blows.
Any idea why???
Old 06-02-2004, 11:42 PM   #2
328is_Perf
i know this might sound stupid... but do you have the fuse with the right amps in?
The ONE and ONLY TRUE ///M3:
E36 ///M3 GTR
328is_Perf is offline   Reply With Quote
Old 06-03-2004, 12:22 AM   #3
Justin e36
Justin e36's Avatar
... I had the same problem. But it always blew no matter if it was left or right.. turned out to be corroded wires touching the chassis of the car. I rewired them.. (cost around $4 for the connectors and everything)... and no problems since.
Old 06-03-2004, 01:57 AM   #4
SickFinga
SickFinga's Avatar
any ideas where i should look??
Old 06-03-2004, 03:55 AM   #5
Quack
Wheelman
Quack's Avatar
look at the wires going into the foglight assembly, those wires are exposed never completely sealed, also check the connectors
Old 06-03-2004, 02:40 PM   #6
Justin e36
Justin e36's Avatar
yep.. bump quack.
try actually pulling the foglight wires and plug out the top of the engine.. (reach down, and pull it up.).. you should be able to examine the wires easily like this, and individually wrap them in electrical tape before trying again...
Old 06-06-2004, 09:44 PM   #7
Betray
Send a message via ICQ to Betray Send a message via AIM to Betray Send a message via MSN to Betray
bump
Betray is offline   Reply With Quote
Old 06-07-2004, 03:00 AM   #8
MP328
Krv Svoju Za Bosnu Moju
MP328's Avatar
Send a message via MSN to MP328
did it start happening just for no reason or did u just change the bulbs?
whats the bulb wattage??
i put once 100W in my fogs and it didnt last a whole night it burned the bulb and the fuse
MP328 is offline   Reply With Quote
Old 06-07-2004, 07:27 AM   #9
Betray
just happened for no reason
Old 06-07-2004, 03:24 PM   #10
MarkD
MarkD's Avatar
Re: Foglight burn out the fuse. WHY???
Any idea why???
You need a bigger fuse. What amperage is the one that is blowing? You will have to increse the capacity by the extra current used by the fog lamps.
Lets's say you have lamps that are 50W each. That is 100W total extra power. Using the formula P = IE, or I = P/I, this would be 100 W / 13.8 V = 7.25 A
So if you have a 15 amp fuse right now, you should change it to the closest size above 15 + 7.25 = 22.25 A which is probably a 25A fuse.
It would be better to run a separate circuit for just the fog lamps with it's own fuse. Then an 8 or 10 amp fuse just for the fogs should be fine.
MarkD
Old 06-08-2004, 05:46 AM   #11
SickFinga
SickFinga's Avatar
MarkD, I don't wanna run anything higher them OEM recommended. It just started happening for no reason whatsoever. The fuse that is burning out is 5A, and it is supposed to be 5A.
Old 06-08-2004, 08:55 AM   #12
MarkD
MarkD's Avatar
Then I misunderstood. I thought you just added some new fog lamps and then started having a problem.
But a 5A fues seems low for that application. How many watts are these fogs? If there is nothing else on the same circuit, a 5A fuse is only good for two lamps that are about 25W each.
MarkD
Old 06-08-2004, 02:21 PM   #13
Justin e36
Justin e36's Avatar
Bigger fuse?... not a good idea.
Fuse is rated depending on the guage wire for the foglights... the fuse is designed to blow before the wire burns out or gets too hot / causes a fire.
higher amp fuse will not burn out.. but the wires will get hot and eventually burn out / cause a fire instead.
Old 06-08-2004, 11:43 PM   #14
BMVV
Fuses offer short circuit protection and over current protection. If this happened out of the blue, you must have a short to ground ( the frame or body) so look for bare copper somewhere.
BMVV is offline   Reply With Quote
