Old 06-22-2002, 11:06 AM   #31
mike125k
Send a message via AIM to mike125k
Originally posted by mkgino
Oh and by the way the check engine light DOES NOT go out on its own, on my 97 328is after my O2 sensor was replaced, the light did not go off by itself. Im not sure on OBD1 cars but thats how it is on OBDII cars.
OBDII check engine light DOES go off on its own once the problem is fixed. it DOESN'T go off as soon as you fix the problem though. the computer needs to go through a certain number of "clean" starts where everything is good. and that number is somewhere between 600-1000 i believe. so yes it will take a while, but it will go off.
1991 318is aka: the torque-less wonder!
mods: TSW Hockenheims, H&R springs, Bilstein shocks, Supersprint exhaust, Jim Conforti chip, K&N, Z3 short shifter conversion, custom made strut tower brace
1988 Ford Ranger STX
mike125k is offline   Reply With Quote
Old 06-23-2002, 12:53 AM   #32
SickFinga
SickFinga's Avatar
I got scaned and reset my light for free at Chuck's Auto Thank you Charlie !!!!!!
To reset your Check Engine light just disconnect your battery.
Thank you Charlie for the tip. 10-15min is enough.
Old 06-23-2002, 02:16 AM   #33
Autotechnica
Little Chino
I always disconnect my -ve battery terminal for 1 hour just to be sure. Either way, just be prepared to get your stock radio's codes and reset all the clocks, etc etc.
Bryan
Autotechnica is online now   Reply With Quote
Old 06-27-2002, 01:08 PM   #34
Euro M3
Peake Tool Codes for E36 OBDI
Chart 5
1 Electrical fuel pump relay
2 Idle speed actuator (close)
3 Fuel Injector, Cyl #5
4 Fuel Injector, Cyl #6
5 Fuel Injector, Cyl #4
6 Fuel Injector, Unknown
7 VANOS (Solenoid)
8 Check engine lamp
0d Oxy sensor
0F Ignition secondary monitor
10 Crankshaft sensor
11 Camshaft sensor
17 Ignition Coil, Cyl #4
18 Ignition Coil, Cyl #6
19 Ignition Coil, Cyl #5
1A Control unit supply
1d Idle speed actuator (open)
1F Fuel Injector, Cyl #3
20 Fuel Injector, Cyl #2
21 Fuel Injector, Cyl #1
24 Evaporative purge control valve
26 Oxy sensor heating relay
29 Air mass sensor
2A Vehicle speed signal not present
30 A/C Compressor control
32 Ignition Coil, Cyl #1
33 Ignition Coil, Cyl #2
34 Ignition Coil, Cyl #3
36 Battery voltage / DME main relay
37 Misfire detected, Cyl #6
39 Ignition timing intervention
41 A/C Compressor
42 DWA/EWS Input
45 Knock Sensor, Cyl 4-6
46 Knock Sensor, Cyl 1-3
49 Throttle position sensor
4C Idle CO Potentiometer
4d Intake air temperature sensor
4E Coolant temperature sensor
52 Intervention, MSR
53 Intervention, ASC
64 Output Stage, Group #1
C8 DME Control Unit
C9 Lambda Control #1
CA Fault code memory error
CC Idle speed increase during MSR
CE Knock control test pulse
dC EWS message
Euro M3 is offline   Reply With Quote
Old 06-27-2002, 11:00 PM   #35
Bill Gates
Bill Gates's Avatar
Send a message via MSN to Bill Gates
i see Pat's point, you shouldn't charge for advice. Thats why were all here, to get tips and advice and share information. if i had the codes, i wouldn't charge for it. if i perform a service for you, then thats another story....
my .02
Bill Gates is offline   Reply With Quote
