Old 05-27-2004, 02:28 AM   #1
BBSe30
Fuel Pressure?
Can someone tell me what the stock fuel pressure should be at on an eta? An 87 325es to be exact....
BBSe30 is offline   Reply With Quote
Old 05-27-2004, 03:23 AM   #2
chromius
chromius's Avatar
2.5 Bar or 36psi
Old 05-27-2004, 11:54 PM   #3
BBSe30
Thank you so much......now I can install the adjustable regulator..
Old 05-28-2004, 01:08 AM   #4
kylebes1
5er world
When installing an adjustible regulator what causes it to increase the output pressure as the engine accelerates? Does it "read" less back pressure on the line to the engine or what?
1984 318i, m50tu powered- RIP
1986 325e, m50tu powered- RIP
1995 525ia, m50tu powered- Same ol same ol
2004 Explorer EB, RIP
1991 300e, m103 powered- Riden LOW
kylebes1 is offline   Reply With Quote
Old 05-28-2004, 01:47 PM   #5
chromius
chromius's Avatar
its connected to a vacume line that is connected to the intake manifold....when you are off the throttle that causes a high vacume condition, and pulls a diaphram in the regulator to essentially open a valve to allow pressure to drop, and when you are on open throttle that causes a low vacume condition and the "valve" closes (not letting as much fuel return to the gas tank) and causes pressure in the rail to increase.
This is essentially how all fuel pressure regulators work adjustable or not. the adjustable ones just have a screw that varries the movement of the "valve" to allow more fuel or less to pass by.
Old 05-28-2004, 07:30 PM   #6
kylebes1
5er world
Sweet
