Old 05-25-2004, 08:45 PM   #16
chromius
chromius's Avatar
damn, I guess I should take a look under there...
Old 05-25-2004, 09:08 PM   #17
qimis
Mr. Euro E30
qimis's Avatar
Originally posted by chromius_e30
Is there anyway to tell if there are holes without pulling up the carpet...in other words, could you guys see these holes from underneath? Cuz on mine there is absolutly no rust under the car.... I am afraid to pull up the carpet now...
yes, you can. (see arrow in the picture) if you see rust spots from outside or a hole going into your interior, try to use a screw driver and poke it. if it goes thru and you feel a cushion / sponge from behind the dead pedal, then there's a hole. make sure you check the other side too !
qimis is offline   Reply With Quote
Old 05-26-2004, 05:49 AM   #18
windsor318is
Nitrous Junkie!
windsor318is's Avatar
geeees, hold ya there was more holes!!! ask ryan, he should knoe how to remove the carpet if you havent dont it yet
Old 05-26-2004, 11:30 AM   #19
Adriano
Who's your daddy now?
Adriano's Avatar
Send a message via MSN to Adriano
Al, your still a slut!
Adriano is offline   Reply With Quote
Old 05-26-2004, 01:00 PM   #20
chromius
chromius's Avatar
Cool thanks...I'll have to check that out this weekend. I'm all scared now...
Old 05-31-2004, 03:10 AM   #21
qimis
Mr. Euro E30
qimis's Avatar
finally i got the hole patched on the passenger side today. i'm telling you taking out that base carpet is just ............. PITA !!!! adriano and al would say "S L U T !!!!!!"
anyways, the gas pedal that i heard was really hard to take it off, came out wasn't that bad. there are 3 clips, covered by the carpet (take the carpet up first) and i ended up made a bigger hole on the carpet around the gas pedal area .
that was the hardest part, taking out the carpet on the driver side, due to all the pedals and lack of room.
here's some pictures from today:
haha ! the base carpet is out
Old 05-31-2004, 03:12 AM   #22
qimis
Mr. Euro E30
qimis's Avatar
freakin rusts ...
Old 05-31-2004, 05:29 AM   #23
windsor318is
Nitrous Junkie!
hahahahha, thats a slut alright!!! can you email me the rest leonard
Old 05-31-2004, 12:47 PM   #24
Adriano
Adriano's Avatar
Holly shit, I didn't see the pic with you giving the bird! That is funny as hell!
Agent BMW trailer
Old 05-31-2004, 03:24 PM   #25
NickP
NickP's Avatar
Sorry I didn't notice the replies until now... there's 4 drains for the sunroof... 2 front and 2 rear... they drain around the rockers just behind the front wheel wells and just in front of the rear wheels.
At each of the 4 rocker ends you'll see 2 openings - use a coat hangar to make sure these are clear. After you do this, open your sunroof and use compressed air to clear these passages from the 4 sunroof drain holes.
Before you put the carpet back in try flowing some water down each drain hole to make sure it doesn't back up anywhere.
Old 05-31-2004, 03:29 PM   #26
ROBM3
ROBM3's Avatar
Send a message via ICQ to ROBM3
LoL... Dont you love Canada.
ROBM3 is offline   Reply With Quote
Old 05-31-2004, 10:36 PM   #27
qimis
Mr. Euro E30
qimis's Avatar
faaaaaaakkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkk
you wont believe what i just found again on the driver's side floor. W A T E R !!!! it rained last night. how the hell did the water came in from ?!?!
Old 06-01-2004, 10:52 AM   #28
Rich 323Cic
Hi, for the trunk, check the taillight gaskets. In my E30 I had a small leak and I traced it to them (water was running down the trunk gutters right on to where the light gaskets were, and then in behind the lights). Once the gaskets were refurbished, it was dry as a bone in there.
Rich 323Cic is offline   Reply With Quote
Old 06-02-2004, 04:39 AM   #29
windsor318is
Nitrous Junkie!
AGAIN!!!!!!!!, did you take the heater vents off to look underneath them at all??? could be another one under there
Old 06-04-2004, 02:15 AM   #30
qimis
Mr. Euro E30
qimis's Avatar
i finally found where's the water coming in from, it's from behind the heater i dont know how the hell the water can come in from there ? i'm thinking to take the blower motor out on the weekend, see if there's a leak thru the firewall in there
