Old 05-25-2004, 02:15 PM   #1
Adriano
Who's your daddy now?
Adriano's Avatar
Send a message via MSN to Adriano
Unhappy Water leaking in the trunk? or My trunk smells like moldy snatch? Part Deux
This is a continuation to the following thread:
http://www.maxbimmer.com/forums/show...threadid=30027
OK, so now we find more vulnerable water leak points in the E30. Again Qimis finds himself in a pool of water in his E30. What is wrong now? We already patched the holes in the trunk and now we find the front carpets to always be wet. WTF!
I figure that if the stones that are flung from the spinning rear tires are enough to wear away at the back of the trunk, then the front tires would also wear away at the front.
Qimis spent many hours pulling his car apart this past weekend (instead of going to Wassaga cruise) and found……. Well….. let the pictures do the talking:
Adriano is offline   Reply With Quote
Old 05-25-2004, 02:19 PM   #2
Adriano
Adriano's Avatar
Wow, pretty soon this car will be like the Flinstones.
I see the light!
Old 05-25-2004, 03:00 PM   #3
NickP
NickP's Avatar
Make sure that your sunroof drains aren't clogged.
Old 05-25-2004, 03:34 PM   #4
Adriano
Adriano's Avatar
Good point Nick but this issue is definately a problem caused by stones kicking up from the wheels which is common to E30s.
Poor Qimis, hic car is starting to look like mine.
Old 05-25-2004, 04:19 PM   #5
bmdoubleya
bmdoubleya's Avatar
Leaky Whores every single one of them...
bmdoubleya is offline   Reply With Quote
Old 05-25-2004, 04:22 PM   #6
bmdoubleya
bmdoubleya's Avatar
Thats a good theory 15 year's of sand blasting must be the cause....
Old 05-25-2004, 05:48 PM   #7
qimis
Mr. Euro E30
qimis's Avatar
uuuhhh ... yikes, yours is worse than mine is that all mud and stuff ?
adriano, thaks for the pictures !
anyone knows how to take out the carpet out ? especially around the gas pedal and below the A/C.
qimis is offline   Reply With Quote
Old 05-25-2004, 05:49 PM   #8
qimis
Mr. Euro E30
qimis's Avatar
where's the exit of the sunroof drains ?
Old 05-25-2004, 06:00 PM   #9
ouch
Old 05-25-2004, 06:14 PM   #10
Jase
twisted beyond reason
Jase's Avatar
you call that a hole..haha
This is what my floor looked like 2 years ago.
Old 05-25-2004, 06:27 PM   #11
Bob Loblaw
Zee Frog.
Bob Loblaw's Avatar
Wow, now THAT's a speed hole!
Anything that makes the car lighter is good, right?? Hehe!
Bob Loblaw is offline   Reply With Quote
Old 05-25-2004, 06:34 PM   #12
Jase
Jase's Avatar
you should have seen the look on my face when i saw that hole. I couldnt figure out how i didnt see it sooner.
Old 05-25-2004, 07:50 PM   #13
BMW BMXer
Wants a 350 Blazer.
BMW BMXer's Avatar
Thats what happens when the holes in your rockers get all bent and clogged.
Stanceiseverything.com
Old 05-25-2004, 08:09 PM   #14
chromius
chromius's Avatar
Is there anyway to tell if there are holes without pulling up the carpet...in other words, could you guys see these holes from underneath? Cuz on mine there is absolutly no rust under the car.... I am afraid to pull up the carpet now...
Old 05-25-2004, 08:43 PM   #15
bmdoubleya
bmdoubleya's Avatar
You should it's the winter driving that does alot of the damage........ My gas pedal fell right out of the floor cause so much water and salt soaks in from the top I could almost guarantee that theres a hole starting under your gas pedal.....
And if the rest of you think you have the biggest HOLE I have you all beat...
