Old 05-18-2004, 08:32 PM   #1
RigsPGT
89-325ix oil specs?
Hi there!
I wanted to change the transmission oil on this car but im not sure what kind is suitable for it. Guys at Autozone checked it on their computer and resulted a Dexron III. Also what other oils should i use for the transfer case and the differential.
Any help would be much appreciated
Rigert
White 89-325ix (winter snowmobile)
Red 1994 Probe GT, KLZE engine, DXD clutch, AWR MMs, Eibachs, Hot Shot Headers +CAI, 2.5" Exhaust with Magnaflow HF converter, 65mm TB, 12" front rotors with Hawk pads, X drilled Brembos, Sleepy eye projectors, kenwood sound.
T3T04E in progress
Got to love 5psi on a 200HP N/A engine
RigsPGT is offline   Reply With Quote
Old 05-19-2004, 07:06 PM   #2
miafori
Send a message via ICQ to miafori
I have no idea of Dexron III. What type of oil is it ? An ATF oil should be suitable for transfer case.
miafori is offline   Reply With Quote
Old 05-20-2004, 07:08 PM   #3
Ace318i
Send a message via ICQ to Ace318i
Dexron III is a specification for ATF oil
I recommend you these oils:
for Diff: Castrol SAF-XO or SAF-XJ (for classic diffs - no LSD)
- specs: 75W90 or 75W140 - SAF-XO or SAF-XJ meets all these requirements.
for engine: M20 engines (little six) - 15W40 oil or 10W40. (15W40 is recommended by BMW for M20s
M40 and M42 engines: (318i or 318is, also E36 318i etc.) - 10W40 or 10W60 (for racing M42s)
Tranny: Dexron III spec. ATF fluid or 75W90 common transmission oil.
Beware - the ATF fluid is very washy, so an old and worn tranny will be noisy. But gearchange will be easy in winter, though...
I love RWD cars:-)
Ace318i is offline   Reply With Quote
Old 05-23-2004, 05:30 AM   #4
RigsPGT
Thanks man!
Do you happen to also know how much differential oil is required? Maybe i might go ahead and change that too
T3T04E in progress
