Old 05-13-2004, 04:02 AM   #1
328is_Perf
Rough Start
TSB 120299
Make: BMW
Model: Various Models
Year: All years
Service Bulletin Number: 120299
Bulletin Sequence Number: 110
Date of Bulletin: 01/00
NHTSA Item Number: SB611091
Component: ENGINE
Summary: CUSTOMER COMPLAINTS OF ENGINE RUNNING ROUGH DURING FIRST FEW MINUTES OF ENGINE OPERATION AND OR ENGINE HESITATES / POOR THROTTLE RESPONSE DURING FIRST FEW MINUTES OF ENGINE OPERATION FOLLOWING INITIAL COLD START ON VARIOUS MODELS PRODUCED FROM 3/96 TO PRESENT.
Motorsport Engine Runs Rough on Cold Start M3 w/S52 (3.2L) manual transmission
M3 w/S52 (3.2L) automatic transmission
Mroadster w/S52 (3.2L) manual trans.
Mcoupe w/S52 (3.2L) manual trans.
does anyone know anything about this? is it a free software update?
well i have the m52 engine ... which is basically the same thing...
it does have a really rough cold start it used to start a whole lot faster... i wonder if this is the same... I REALLY NEED A FIX! it only has 69 k miles... about 100k kms..
The ONE and ONLY TRUE ///M3:
E36 ///M3 GTR
328is_Perf is offline   Reply With Quote
Old 05-13-2004, 12:23 PM   #2
Andrushka
Yep. I think I get this on my 2004 E46. When you first get in the car, wether its morning day or night, and you don't warm it up for at least 5 minutes, when you shift into Drive (i have an auto), give it some gas, the engine will begin to revv, but the car won't move. In about 3-5 seconds it suddenly grips though, and starts moving. I don't know what it is. I'll have the dealer check it out when I service it. It's a pretty common problem, but only on some cars for some reason. I didn't have it on my x5, and my family's 330ci doesn't have that either...Go figure.
Another common problem is the Harman Kardon gets distorted at higher volumes on he passengers side. Tres bizarre.
2004 330xi Orient Blue on Gray leather. Premium Pkg.
Mod List:
HKS Cold Air Intake
Pulleys
Grounding Wires
Rockford Fosgate system two 12's and 1001 bd amp. Custom installation.
Carbon Fibre roundels
debadged
M3 Lip Spoiler
Aluminum Sport Pedals
Aluminum Shifter
Ultra Special custom phone holder from Bimmian.com
15% Tint
Andrushka is offline   Reply With Quote
Old 05-13-2004, 03:01 PM   #3
bmwboy88
Andrushka
Here is the TSB for your problem: You need to have the transmission replaced. I also have this problem but have no time to visit the dealer. If you do go see the dealer about this problem, please let me know what they said. See below about the TSB:
SIB 24 07 03 Feb 2004
Automatic Transmissions Service Engineering
__________________________________________________ _________________
This Service Information bulletin supersedes SIB24 07 03 dated December 2003
Subject
GM5: Delayed P to D Engagement on Cold Start
Model
E46 with GM5: 325iA, 325xiA, 325xiTA, 330xiA from 09/02 up to 12/03
E46 with GM5: 325CiA, 325CicA, 330iA, 330CiA, 330CicA, 325iTA, from 03/03 up to 12/03
E53 X5 3.0iA with GM5 from 09/02 up to 12/03
E83 X3 3.0iA with GM5 from introduction up to 12/03
Situation
Customer may complain of delayed P to D engagement (2 to 30 seconds) during the first cold start in the morning
Cause
Unfavorable tolerances of C1 clutch housing causing internal transmission pressure leak after extended (overnight) parking
Correction
ON A CUSTOMER COMPLAINT BASIS ONLY, after verifying the above mentioned situation,
REPLACE THE TRANSMISSION WITH THE IMPROVED UNIT
For transmission replacement procedure refer to RA 24 00 048 found in BMW TIS.
Important
Gm5 automatic transmissions replaced under the terms of this Service Information DO NOT require any technical Hot Line authorization contact number.
PARTS INFORMATION
Part Number Description Quantity
07 12 9 900 047 M12x1.5 self locking nut for output flange 3
24 00 7 515 157 GM5 trans for 325xiA/xiTA from 09/02 up to 03/03 1
24 00 7 523 279 GM5 trans for 325xiA/xiTA from 03/03 1
24 00 7 515 279 GM5 trans for 330xiA from 09/02 up to 03/03 1
24 00 7 523 281 GM5 trans for 330xiA from 03/03; and X3 3.0A 1
BMW = ULTIMATE DRIVING SENSATION
bmwboy88 is offline   Reply With Quote
Old 05-13-2004, 04:29 PM   #4
Andrushka
thanks bro. I'll definetly let u know.
Mod List:
HKS Cold Air Intake
Pulleys
Grounding Wires
debadged
M3 Lip Spoiler
Aluminum Shifter
15% Tint
