Old 05-12-2004, 03:08 PM   #1
Three_1_Eight
Three_1_Eight's Avatar
How do you...?
Hi,
One of my rear license plate lights burnt out on my 1994 318is and I would like to replace it. Do I just have to unscrew the four screws around the lights on the outside of the trunck and the assembly basically pops off?
Any help would be appreciated.
Tom
Three_1_Eight is offline   Reply With Quote
Old 05-12-2004, 03:22 PM   #2
Justin e36
Justin e36's Avatar
pop your trunk.
under the trunk handle you will see 4 screws. (two on the outside, two on the inside)
unscrew these. (the screwdriver in your toolkit will work for this!)
pull off the trunk handle.
slide and pull the blown bulb out.
put in the new bulb securely.
turn on your lights, make sure it works fine and try rattling the bulb holder to make sure it's secure. (and there isn't a short in the wire! ... E36's are known for having flickering license plate bulbs when going over bumps.. hence why they blow so quickly!).
All looks good? ... Turn the lights off... snap the holder back in place and screw the trunk handle back on.
* Do not put in the bulb while the lights are on... chance you could cause a power spike and blow a fuse.
Good luck!
J
Old 05-12-2004, 06:39 PM   #3
Three_1_Eight
Awesome Justin, Thanks!
