Old 05-11-2004, 06:03 PM   #1
BMW_M52_M20
E30 woes........Solution hopefully!
Okay Guys,
I have had an on going problem with eratic idle (hunting) and my car cuts out on and off during acceleration and has poor cold starts. I have exhausted every option before diving into the fuel injectors:
Here are the items I have replaced for similar problems:
Fuel pump
Fuel lines
Fuel tank
Fuel filter
ICV valve and module
vaccum hoses
spark plugs
cap and rotor
ignition wires
Cold start valve
Anyways, enough was enough and I took it over to my Mechanic at Cross Avenue and he is replacing all 6 fuel injectors (OEM BMW)
and installing a new fuel pressure regulator. Each fuel injector is $177.00!!!!
I am going to hold on to this car for a bit and I have sunk a lot of money into this car so I am praying this will solve my problems. I can't see what else there could be left to do.
I will let you guys know tonight on how things went.
Past: 1998 323is (E36)
1986 325e (E30)
Present: 1997 Jetta GLX VR6
2004 325iT (E46) (pops)
Old 05-11-2004, 06:22 PM   #2
Slowered318
what about the coolant temp sensor.. i'm replacing that in my bro's 325 i'll let you know if it fixes the problem of rough idle and bad cold starts
Old 05-11-2004, 06:40 PM   #3
BMW_M52_M20
Sorry, forgot to add that to my list, has already been done!
1986 325e (E30)
Old 05-11-2004, 07:15 PM   #4
Slowered318
and that didn't fix it obviously.. damn
Old 05-11-2004, 07:33 PM   #5
felixthecat
Was touched by Micheal
felixthecat's Avatar
damn bud....i would nave given you 6 injectors...i have a bunch from my other motor i'll never use...
Old 05-11-2004, 07:38 PM   #6
BMW_M52_M20
Nope. It has been an on going battle, but I figure, hey I put the money into it, I will have nice original bimmer that I can just mess around with in the summer. I have to get another car by the end of the summer anyway.
1986 325e (E30)
Old 05-11-2004, 11:00 PM   #7
Jase
twisted beyond reason
Jase's Avatar
Is the car pushing any smoke?
Jase
Old 05-11-2004, 11:44 PM   #8
BMW_M52_M20
nope, very clean running actually.
1986 325e (E30)
Old 05-12-2004, 01:17 AM   #9
bmdoubleya
bmdoubleya's Avatar
Have you replaced your AFM??? My buddy's 4 door had the same problems ... We replaced the AFM and fixed the problem for the season but then it came back the next years... That time it was the rubber intake boot had cracks in it which was letting in un-metered air..
Check your intake boot for cracks and tape it up or replace it.
bmdoubleya is offline   Reply With Quote
Old 05-12-2004, 09:28 AM   #10
Sim_Sima
The Sims
Sim_Sima's Avatar
Dude a bad idle doesn't always mean its the fuel injectors, what about the O2 sensor located under the exhaost manifold. It due to be replaced now and eventually all the e30 will have to do this too.
Sim_Sima is offline   Reply With Quote
Old 05-12-2004, 02:38 PM   #11
BMW_M52_M20
I am sorry guys I am not posting everything I have replaced, I have replace the intake boot and all vaccum hoses and my AFM as well as my 02 sensor.
Tell what other options it could possibly be, because I am out of options.
1986 325e (E30)
Old 05-12-2004, 03:22 PM   #12
chromius
chromius's Avatar
Dude...the $170 a piece the dealer asks for fuel injectors is insane....you can get a whole set of OE injectors for $180 US! and its a DIY job too. But aside from that, the fuel pressure reg is definitly a good start, and so are the injectors....replacing mine fixed my hunting idle and rough idle too. If that dosn't fix it....the only things left that it could be are either the ECU, especially if you have motronic 1.1...or there is excessive carbon/tar buildup on your valves/intake manifold/throttle body.
