Old 05-08-2004, 11:40 PM   #1
mikee30
Looking to buy a shifter
Stock, aftermarket, lit or not....just something nice for my e30. The one I got with the car is horrible.
Oh yeah, if anyone has an aftermarket parking brake boot, I'm looking for one of those as well
Car is a 90 325i
Mike
mikee30 is offline   Reply With Quote
Old 05-09-2004, 03:54 AM   #2
johnoz
/OO=[][]=OO\
johnoz's Avatar
PiCK ANY OF THESE, PRICES ARE IN US
Parts needed for a E30 upgrade:
Qty P# Description Sugg-Retail
1 25 11 1 434 148 Z3 1.9L shift lever 52.50
1 25 11 2 220 600 Nylon ball joint cup 11.15
2 25 11 1 220 439 Washers 0.84
1 25 11 1 220 379 Circlip 0.51
1 25 11 1 221 822 Carrier Bushing 5.24
1 25 11 1 221 569 shifter suspension bush 22.00
BMW sugg retail is $92.42
Bush bearing 25 11 1 220 832 $8.76
Trans shift bush 25 11 1 463 397 $11.92
* 6 supt brkt 25 11 1 220 707 $20.34
Spec. circlip 25 11 1 220 379 $0.54
Spec. shim 25 11 1 220 439 $1.14
Bolt 25 11 1 225 344 $6.90
http://www.unofficialbmw.com/images/selrod1.gif
25-11-7-516-160 Shift Lever
31-33-1-092-887 Nut
25-11-1-220-379 Spec. Circlip
25-11-1-220-439 Spec. Shim
25-11-7-501-309 Joint
25-11-1-221-849 Guide Pin
25-11-1-220-832 6-Bush Bearing
25-11-1-220-707 6-Supt. Brkt
25-11-1-220-439 Spec Shim
25-11-1-469-397 Trans. Shifter Bushick any o
johnoz is offline   Reply With Quote
Old 05-09-2004, 03:49 PM   #3
mikee30
Thanks for the info.
I was just looking for a regular shifter actually, but maybe I might do this swap.
Does the transmission need to be removed to install new bushings? Or is all the work done from inside the car?
Thanks again
Old 05-09-2004, 07:39 PM   #4
felixthecat
Was touched by Micheal
felixthecat's Avatar
tranny+motor have to be tipped back so you can get up and in there,its a shty job.You have to drop the exhaust,remove the heat sheild,transbrace,rad hoses if there too tight,unbolt the doughnut,way too much sht to do for such a small mod....just wait untill the bushings are shot,then do it....
Old 05-10-2004, 04:07 AM   #5
mikee30
Agreed.
Okay...does anyone have just the shifter knob for sale? Even if it's the original one I don't mind..I just have to get rid of the one I have right now...I can't stand it.
Thanks!
Old 05-10-2004, 04:13 AM   #6
Goran
Send a message via ICQ to Goran
if you are looking for a stock shifter rod i have one no bushings though
Goran is offline   Reply With Quote
Old 05-11-2004, 03:44 AM   #7
mikee30
I just need the shifter knob....nothing else.
